Honda CR-V & Element 2WD & 4WD Element & CR-V
false misfire codes on 2001 crv
Old Sep 14, 2017 | 10:14 AM
old tech's Avatar
Default false misfire codes on 2001 crv
getting 1399, 302 and 304, engine runs fine
Old Sep 15, 2017 | 04:37 AM
ThisIsMatt's Avatar
Default Re: false misfire codes on 2001 crv
Is the engine light lit solidly or actively flashing? The ECM's code parameters are a lot more sensitive than we are as drivers and sometimes a misfire event will be subtle enough that you won't notice it. If the light is flashing, the engine is actively misfiring. If the light is solidly lit and a misfire code is read, the misfire event isn't actively happening and the engine may in fact be running fine at that moment, but the misfire has already occurred and may happen again.
98dxkoupe
Oct 2, 2018 04:32 PM
hkhaperey
Apr 30, 2007 07:15 AM
eg686
Apr 18, 2003 01:01 PM
97GSR
Nov 12, 2001 06:30 AM
