B18a1 Where does this hoes go?
Old Sep 10, 2017 | 06:13 AM
MastaFlyMason's Avatar
Default B18a1 Where does this hoes go?
On a B18a1 OB1 from a 93 Integra. It's actually swapped into a CRX if that matters. The one below the coolant inlet. I'm doing a B swap and I think I have all the coolant lines routed correctly but I don't see where this one would go. I am following the diagram below and I can't tell where it is supposed to go. It looks like it goes to the bottom of the throttle body but I don't see any extra places to hook it up. One goes from my MAF (i think?) to the rear of the engine and the other side of the MAF is looped to the bottom of the throttle body, from there it goes to the tstat housing. Then there are two lines from something else on the bottom of the intake that go to the T stat housing.
Old Sep 10, 2017 | 09:51 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: B18a1 Where does this hoes go?
Heater core inlet hose.
Old Sep 10, 2017 | 01:41 PM
I think that's the one above it. I'm talking about the one that already has a piece of hose connected in the pic above
Old Sep 10, 2017 | 04:43 PM
akenwph's Avatar
these hoes aint loyal
Old Sep 11, 2017 | 03:05 AM
NVturbo's Avatar
O.G. triple O.G.
Hoes go wherever the $$$ is.
Old Sep 11, 2017 | 06:38 AM
TheShodan's Avatar
Moderator
Please refer to the Tech/Misc thread. I'm recommending that these threads merge. Please MastaFlyMason, one topic for each thread, only. Do not put the same inquiry/topic in multiple threads simply because you're not getting a response to one fast enough. Thanks.
https://honda-tech.com/forums/tech-m...-hose-3306783/
Old Sep 13, 2017 | 05:37 PM
m4xwellmurd3r's Avatar
That hose goes to the Throttle body.
https://postimg.org/image/bxw2r6s3j/
You want the diagram for the B18B1 not the A1
Old Sep 14, 2017 | 05:11 PM
wunfstgsr's Avatar
Loved
Community Favorite
Goes to bottom of the throttle body, to the Iacv then from Iacv to the back of the block I believe to the water pipe that feeds the water pump, some year models have 2 ports and some have 1 if I'm not mistaken, as well as certain year engines came with a fitting on the thermostat housing and some not. On my gsr I believe it's like that and on my Type R motor it doesn't, I deleted those hoses completely as I don't need them cause there there for cold weather areas where you need the coolant to keep the iacv from freazing, my after market throttle body doesn't have the lower ports for the coolant so that's why I deleted those on my ITR engine, your LS is a bit differently setup but similar as far as the coolant hoses from there to the iacv to the back of the engine.
MurtazaDSM
Nov 27, 2023 05:22 PM
ska24
K Series
May 20, 2019 07:22 AM
Wyatt87
Aug 15, 2012 12:48 PM
EF8IGHT
Nov 8, 2005 07:53 AM
85mm LS VTEC
Apr 11, 2005 11:06 AM
