Contemplating DIY Socketing a B20 ECU for a dynomometer tune session
1995 Civic EX coupe with JDM B20b block, LS intake (non-vtec), P75 Intake manifold, GSR 60mm TB, 240 cc injectors. LS manual transmission. I purchased the car five months ago and previous owner did all the swaps but, he never had it socketted and tuned. Engine supposedly has 70k miles, new a/c system, I de-powered the steering rack (removed rack seal), stock pinion gear.
I don't have any previous experience with ECU modding or dyno tuning and I'm not looking to have it tuned necissarily for hp and torque gains (though a benefit)..It seems to be running slightly lean and from info I've read online this is typical for my car's setup without a socketted ECU and dyno tune. The stock P75 ECU injects for a 1.8L and not for a 2.0L displacment. The tuner I spoke with said that with a proper ECU mod and dyno tune I can expect 130 whp and increased torque, it will get better gas mielage, engine will run smoother and in a stoichiometric state.
The person i spoke with said I can purchase an ECU through them, source my own, or DIY socket my own..he said don't chip it though. Seeking opinions on which way I should go and if I do go DIY which socket kit I should purchase? I have a good amount of soldering experience and would be comfortable attempting DIY.
Socketing a virgin ecu is pretty straightforward. Just make sure you find one of the guides at Moates.net or wherever, let it soak in, and then read it again. Hopefully you have a nice iron with a decently fine tip. I get most of my stuff from Moates.net, but have done business xenocron.com, hamotorsports.com and phearable.net as well, and can recommend any one of them.
The B20, even in its stock low compression form, responds well to a good tune. Find a decent tuner and make sure they are using a load bearing dyno, as opposed to a simpler inertial one. It's the difference between being able to properly tune the entire map (which is what you NEED for a street car) as opposed to only being able to really tune the WOT line. I'd also recommend that you step up to the plate and find a NepTune/Demon board or Hondata s300, it really is an investment for the long run if you want to be able to grow the engine in any way, or to have the ability to customize things to your liking.
Hondata and NepTune ARE the mid-level options.
NepTune has a chip tune option for its dealers/certified tuners. Not sure is Hondata offers that at all. The only other option that I am aware of currently is CROME, and that platform is mediocre at best but will get you by if it's all you can muster.
Yes, you will need the other components in that picture. They are required for the chipped ecu to function and to enable datalogging. Tuning without data is just guessing.
NepTune has a chip tune option for its dealers/certified tuners. Not sure is Hondata offers that at all. The only other option that I am aware of currently is CROME, and that platform is mediocre at best but will get you by if it's all you can muster. Yes, you will need the other components in that picture. They are required for the chipped ecu to function and to enable datalogging. Tuning without data is just guessing.
Traction
Sep 12, 2004 09:55 PM
