DOHC ZC cam timing problem?
Old Jul 19, 2017 | 03:27 AM
antonio1122's Avatar
Default DOHC ZC cam timing problem?
Added wrong picture from cam timing, will re-do it and post it here.
Is my timing off? Idle feels like backfiring just a little and when I try to take off idle and I press the gas pedal hard it has delay and hesitation. If I do it slowly its fine, I've replaced and adjusted TPS, IACV, cleaned intake manifold, new spark plugs, a year old barely used spark wires. Other than that car runs fine I guess, not sure if timing was like this prior to 6 months, never checked it to ne honest. Thank you.
Originally Posted by tony_2018
Define poor throttle response.
Car is idling, you press the gas pedal it delays and you can hear intake(afternarket CAI) yet it delays then brings RPM's up, like something is choking engine. If you press gas pedal slow, it doesnt delay however its annoying as hell to drive like that, you cant press gas pedal hard yet you have to play it very gently and slow, once I get off from dead stop, it has no issues. Also if I open throttle like 5% and then stamp on it, it doesnt delay. TB and IM are both cleaned, butterfly doesnt stick, TPS is adjusted and has no dead spots, IACV is replaced as well. On idle also when warm feels like its a little jerky like engine is shaking a little, you can feel it from inside however RPM's are consistent, like it missfires but it doesnt, its impossible to explain it unless you feel it though which is impossible.. other than that everything works just fine. Btw ever since I bought it, it wants to stall when started warm and then picks up if I give it some throttle.
Old Jul 19, 2017 | 03:29 AM
Default Re: DOHC ZC cam timing problem?
Will edit when I get back from work, posted wrong picture.
Old Jul 19, 2017 | 05:06 AM
DumpdEJ6's Avatar
I like the tuna here
Send a picture with them lined up how they are supposed to be.
Old Jul 19, 2017 | 06:45 AM
tony_2018's Avatar
Fish Twig
If you're unable to provide images of the cam's lined up and crank at tdc, you got better issues to worry bout.
Old Jul 19, 2017 | 07:26 AM
Lol I posted wrong pictures was in a hurry. I'll update when I get back from work sorry though, I genuinely didnt notice. As per poor throttle response unless its timing, what else considering everything is replaced and ECU throws no codes. Thank you.
Old Jul 19, 2017 | 07:48 AM
tony_2018's Avatar
Fish Twig
Old Jul 19, 2017 | 08:04 AM
stealth civic
Jun 12, 2019 01:52 PM
EFyew
Jun 17, 2012 07:40 PM
Voodooboy520
35
Jan 5, 2006 12:59 PM
1990 CRX Si
Nov 15, 2005 12:09 PM
efjuice
Oct 14, 2003 09:36 AM
