IIIgen 2.0 AT - problem with gearbox
Old Jul 11, 2017 | 12:10 PM
boncky's Avatar
Default IIIgen 2.0 AT - problem with gearbox
Hello,
I have a problem, please help. I have Prelude III GEN 89r. 2.0 automatic transmission. I have problem with gearbox if i not let go gas, he will dont change I have to push it on at least 4,500 RPM and let go lightly RPM - than gearbox change, what's the matter?
1. The gearbox does not show errors
2. The engine does not show errors
3. Oil in the box replaced.
4. Solenoid - check its OK
Sorry for grammar !
Old Jul 11, 2017 | 07:23 PM
H22Honda98's Avatar
Default Re: IIIgen 2.0 AT - problem with gearbox
Man you havr to find a way to articulate your problem a little better. I don't understand the issue here
Old Jul 12, 2017 | 05:45 AM
snobordboy's Avatar
Moderator
From what I gather, the transmission will not shift gears until the engine reaches 4,500 rpm or more and the throttle is released.
I am not knowledgeable about auto trans, but if the torque converter has an issue, would it keep the transmission loaded up and not allow it to shift?
Is there a cable that controls kickdown that could be out of adjustment or stuck to keep it from shifting?
Old Jul 12, 2017 | 11:19 AM
boncky's Avatar
At first: Sorry for my language
two: the transmission will not shift gears until the engine reaches 4,500 rpm or more and the throttle is released
kick down - check, its OK
zeroslav
Transmission & Drivetrain
Apr 21, 2018 09:48 AM
generalgeorge
Oct 28, 2008 06:11 AM
eurowned
Jan 15, 2008 11:59 AM
Extreez
Aug 26, 2006 11:16 AM
djtech
Feb 19, 2003 06:13 PM
