D16 Turbo Downpipe hitting oil pan
Old Jul 6, 2017 | 10:27 AM
Rough124's Avatar
Default D16 Turbo Downpipe hitting oil pan
Hey guys, i've tried to search about this problem but didn't really find anything. The thing is that i bought a turbo kit from ebay but the downpipe doesn't fit, it hits my oil pan on the flex pipe side. The turbo is mounted with the compressor housing facing the gearbox ( it doesn't fit any other way). I could put it backwards but i have the long curvy downpipe, another problem is that even if i would be able to fix the downpipe it will end up being too long. Any ideas how to fix this?
Old Jul 6, 2017 | 11:10 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: D16 Turbo Downpipe hitting oil pan
Moved to forced induction as there may be more experience with such issues here over the 92-00 civic/sol section.
Old Jul 6, 2017 | 11:30 AM
k20z1ej1's Avatar
take it to an experienced welder or an exhaust shop
Old Jul 6, 2017 | 11:31 AM
Chance EG's Avatar
You'll probably need to have another one fabricated. Check with local shops, downpipes usually aren't terribly hard to make. Since your kit is likely intended to be AC compatible and it has that "twist" section it will be somewhat more difficult, but still probably shouldn't break the bank.
Old Jul 6, 2017 | 12:12 PM
Schister66's Avatar
Man U FTW
i bought a turbo kit from ebay but the downpipe doesn't fit.
The Problem: eBay parts. They're cheap for a reason.
Solution: Buy a proper turbo setup. I wouldn't sink another dime into this - its past the point of diminishing returns
Old Jul 6, 2017 | 04:46 PM
Roy Leyva's Avatar
Use open DP
Old Jul 6, 2017 | 05:06 PM
th3pwn3r's Avatar
Originally Posted by Roy Leyva
Use open DP
Pretty much this. What I had to do was cut my downpipe basically flush with the bottom of the oil pan where it was going to run across the pan. There's no ground clearance anyways, if you want to have an actual exhaust you're going to have to get a downpipe fabbed up. You can get a lot of experience putting an Ebay kit together due to everything being a pain in the butt haha.
Autoworks
May 31, 2006 08:37 PM
Turboredteg
Jan 30, 2005 04:43 PM
2000vsm
Aug 7, 2003 09:30 AM
Tetronious
May 24, 2003 04:30 AM
92JDMSiR
Apr 27, 2002 04:39 AM
