Best MAP sensor for 1.5
We are racing a 86 civic with a 1.5 on a 1/4 mile oval asphalt track and must be 100% stock. I believe the MAP sensor is bad and need to replace it. the original OEM one cost 250.00 . Could i use one from a later model that cost less?
junk yard, or a wrecked civic from 1990-2001. They are all the same Denso MAP sensor
ohhhhh... That's a different animal altogether from the other D/B/H/F series that were the standard.
*Edit* I just realized it was from a 1986 MAP sensor. That's OBD0. You're better off going to the junkyard as I stated.
.. Sorry about that. !
baulum
Apr 13, 2008 10:18 PM
