Brake rotor rubbing against my caliper bracket.
Old Jun 22, 2017 | 03:35 PM
Silentz's Avatar
Default Brake rotor rubbing against my caliper bracket.
Hey guys, I was changing my right axle and noticed my rotor is rubbing against the caliper bracket. Unfortunately, I drove it a very short distance before I realized it.I took the new axle out and put the old axle back in with the old axle nut and it still rubs. Wheel bearing spins fine and smooth. Here are the pictures.
Brake rotor rubbing against the outer caliper bracket. - Album on Imgur
Any idea would be greatly appreciated. I'm at a lost here
Thanks everybody.
Old Jun 23, 2017 | 05:09 AM
mk378's Avatar
Default Re: Brake rotor rubbing against my caliper bracket.
It looks like the wheel hub is coming out of the bearing. That is not supposed to happen if the axle nut is kept tight. The two parts should be flush with each other on the inside.
Tightness is (IIRC) on the order of 150 ft-lb.
Old Jun 23, 2017 | 01:35 PM
Silentz's Avatar
Oh, this might be it!
So, do I just hammer the wheel hub back in or it is bad now?
Thanks for the help :D
Old Jun 25, 2017 | 01:36 AM
eghatch9295's Avatar
Stancetard Hate Monger
pressed in bearings. no.
Old Jun 25, 2017 | 02:26 PM
Silentz's Avatar
Ok, I brought it to a shop near me and they pressed the wheel hub and bearing in and for some reason, it still rubs. Any idea?
Thanks
Old Jun 25, 2017 | 08:41 PM
is this car new to you? are you sure you have the appropriate caliper and bracket for your hub? is the bracket installed on the correct side?
Old Jun 26, 2017 | 07:47 AM
94eg!'s Avatar
#1 Super Guy
Loved
The only thing I can think of is that the wheel bearing has too much play in it. Or you have a bent caliper bracket.
Old Jun 26, 2017 | 12:45 PM
Silentz's Avatar
I had this car for a while and this is my first time doing axle on this car. I did forgot to tighten the axle nut and backed out of the drive way before stopping. I think the bracket might've bent like 94EG! suggested.
Old Jun 26, 2017 | 12:46 PM
Silentz's Avatar
This is probably the cause here. I'll take off the hub assembly on the other side sometime this week and compare them thoroughly.
Old Jul 2, 2017 | 05:11 PM
Silentz's Avatar
OK. This is really simple to fix and I feel like a dunce after I figured it out.
See those washers on the bolts? They don't go on the bolts, they go between the caliper bracket and the hub assembly and you slot the bolt through them.
Hope your problem is the same as mine. Good luck!
Old Jul 3, 2017 | 05:12 AM
mk378's Avatar
No, there aren't supposed to be washers there. That is a compensation for something else being wrong. In a stock setup, the bracket bolts directly onto the knuckle. I don't think there are even washers under the bolt heads. Most likely a previous owner used the wrong parts somewhere.
Old Jul 5, 2017 | 10:52 PM
Silentz's Avatar
Seems like it but either way, I'm happy it works now and running properly
Old Dec 30, 2022 | 07:19 AM
Sk3l3t0n3's Avatar
Did you ever figure out what it really was and end up removing the washers? I am having the same issue with a CRV. We actually just tried the washers and it fixed the issue, before I read this thread… I was like “wow, is this the same vehicle?” lol
skwigelf
Nov 10, 2014 03:15 PM
UniversalSystem
Jul 17, 2013 07:59 PM
nickohlassss
18
Aug 25, 2008 07:22 PM
kinkyintegra
Oct 6, 2005 04:03 AM
krshultz
Sep 17, 2004 05:21 PM
