Suggestions Request: B16 Intake manifold & Throttle Body Options
Old Jun 20, 2017 | 03:50 PM
MYEMWON's Avatar
Default Suggestions Request: B16 Intake manifold & Throttle Body Options
Hey guys, looking for someone to point me in the right direction for my throttle body and intake. Currently upping the stakes on my b16 build. 81.5mm bore, 10.5 c/r fully built head, GE sleeves, Weisco pistons, Manley turbo tuff 625 rods precision 6266 etc.. Now that generalities are out and in the open, I currently have the skunk2 ultra street intake manifold and skunk2 70mm TB from when I just wanted 500hp. I was thinking about growing up to the Skunk2 Ultra race intake manifold but I am unsure as to what size to use based off their scale (their scale goes up to 3.5L). I am also unsure about going bigger than a 74mm TB seeing as they have space for a 90mm but I think that that may just be overkill. Having enough fuel won't be the issue I'm just concerned with how big to go with the TB and intake manifold. Any suggestions....aside from different brands would be greatly appreciated.
Old Jun 20, 2017 | 10:49 PM
2kdrift's Avatar
Default re: Suggestions Request: B16 Intake manifold & Throttle Body Options
skunk2 street with 70MM is more then enuff for most setups, what are your power goals?
I dont think a bigger manifold is going to do much other then change the power band a bit
Old Jun 21, 2017 | 07:13 AM
MYEMWON's Avatar
We are hoping for anywhere between 650-750 on e85.
Old Jun 22, 2017 | 12:44 AM
extremeracer's Avatar
I run a Edelbrock Victor X with Skunk "Alpha" 70mm cast throttle. Cost effective and simple setup.
That isn't to say that the Skunnk2 Ultra series aren't better though.
Since you already have the Street Manifold and 70mm, just run it and see whether you reach your intended power and powerband target. If not, then switch to the Ultra...
Old Jun 22, 2017 | 03:55 AM
Balor_Gr's Avatar
The "other" manifold gonna play a bigger role on this powergoal
Id keep this intake manifold.
If you really want to hit 750 you can allways go ***** deep and go for a gato/magnus or even mod yours to make it dual plenum wrc style.
Old Jun 22, 2017 | 06:03 AM
ssmrico's Avatar
u should be fine. I have the edelbrock one and also seen it make 900+ so for my goal and yours should be more than fine
Old Jun 22, 2017 | 07:27 AM
AZ_CIVIC's Avatar
I agree, I was running an Victor X and Blox 76mm throttle body and made 1060whp with it and ran 8's. Cheap and efficient.
Old Jun 22, 2017 | 09:30 AM
MYEMWON's Avatar
So would it be best to upgrade to 74mm TB alone; or would I just be pissing into the wind at that point?
Old Jun 22, 2017 | 09:52 AM
LightningTeg's Avatar
Community Builder
Pissing in the wind lol. You're just going to lose throttle response with a bigger TB. I'm still factory @650whpish
Old Jun 22, 2017 | 11:39 AM
AZ_CIVIC's Avatar
Default Re: Suggestions Request: B16 Intake manifold suggestions
No, I was using a stock Type R throttle body on my Victor X over 900whp. Only switched to the 76mm when I jumped to my 6870 and now I am on an Accufab 90mm, BMC manifold, Web Pro cams and a turbo that made 1350WHP so I need as much airflow as possible.
For 700whp a Victor X and Type R throttle body would be just fine. Since you have the 70 I would just stick with that though.
Old Jul 7, 2017 | 10:06 PM
B and B's Avatar
Loved
Community Favorite
Default Re: Suggestions Request: B16 Intake manifold & Throttle Body Options
TB sellers are McLuvin ya'll......
(Rock the polished LS)
Steeve_Civic
Jan 19, 2014 04:28 AM
stutler_jdm
May 14, 2011 09:05 PM
k20rsx1
Sep 21, 2009 09:09 PM
whiteboy-dc4
Sep 16, 2008 09:39 PM
dave24
Jan 5, 2006 05:13 PM
