Transmission & Drivetrain Gearboxes, Differentials, Clutches
New synchro tech crx si tranny vss help
Old Jun 12, 2017 | 02:28 PM
SupremeDalek209's Avatar
10 Year Member
Default New synchro tech crx si tranny vss help
Hello,
I installed my new rebuilt synchro tech trannismission and there is a hole meant for the VSS. Problem is I can't remove my unit from my old tranny.
Does anyone know the part number. I know it should just come out after its unbolted, but the bastard isn't coming out. It's the hollow cylinder shaped metal piece the cable mates with.
thank you,
-5upr3me
As you can see it got chipped after i put a flat head underneath haha.
Old Jun 12, 2017 | 11:29 PM
holmesnmanny's Avatar
Default Re: New synchro tech crx si tranny vss help
lock some vice grips on it and try to tap it out, after trying to put it in gear and moving the input shaft to wiggle it loose
it's likely just putting it in gear and turning the mainshaft will free it up
Old Jun 13, 2017 | 02:27 PM
Aquafina's Avatar
Being in gear or not has nothing to do with removing the VSS. The cable VSS's being stuck is a very common problem. You'll probably need to split the case to pry it out if you want to get it out intact.
You won't be able to order it, it has been discontinued.
Old Jun 13, 2017 | 09:05 PM
Sure it does. I know from experience. It's not just being in gear, it's just the spot that the vss is at in relation to being in gear that somehow makes it stick.
Old Jun 14, 2017 | 12:45 PM
Aquafina's Avatar
The VSS reads off the plastic gear on the diff. Being in gear or not does absolutely nothing to the diff or the VSS. The VSS holder cannot spin (if you can spin it then it will be easy to remove) so rotating the mainshaft in gear will only spin the VSS itself which does absolutely nothing to free the VSS holder. They stick because its a tight interference fit on 26+ year old transmissions.
RobEK
Jun 3, 2009 08:21 AM
Turbo Dan
10
May 15, 2008 11:25 PM
pauld
Jun 17, 2007 06:04 PM
Markb16a
Jan 27, 2006 06:54 PM
