Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Outrageous AC quote
Old Jun 12, 2017 | 06:49 AM
Kirby179's Avatar
Default Outrageous AC quote
Took my hybrid in to get the AC recharged, normal mechanic didn't have the device to diagnose because it's a hybrid (something with how it hooks into the electrical system). Got a call about 20 minutes ago saying it'll be ~2200 because the compressor failed, and took the clutch and schraeder valve with it. It's "1100 in parts alone" - I'm not confident in anything beyond changing my oil, and even then I don't have the tools or space to do *that* where I am right now. I have to assume I should get a second opinion here, but what should I expect?
Old Jun 12, 2017 | 07:23 AM
Kirby179's Avatar
Default Re: Outrageous AC quote
Update: Got some more information from another local mechanic; apparently the complication is because because the AC ties into the high voltage end of the electrical system on the 8th gen Hybrids, and only the dealership in the area has the equipment to work on it (diagnostic or repair). Also with it being high voltage, I'm completely not willing to try it on my own.
Old Jun 12, 2017 | 11:23 PM
holmesnmanny's Avatar
And this is the real reason they made hybrids. What a complete ripoff this makes hybrids become. I would check on Yelp for mechanics that might have the equipment to service it that have good reviews.
Old Jun 14, 2017 | 12:36 PM
2x0's Avatar
2x0
10 Year Member
Sounds a little high, but not that outrageous. When a compressor fails, you have to not only replace the compressor, but also the expansion valve, receiver dryer, and the condenser is recommended because the newer types cannot be flushed. The NAPA shop by me quotes about $800 in parts plus the same in labor for all of this, I've checked around and that seems to be the norm.
I tried going a cheaper route and replacing a compressor myself with a new unit from Rock Auto for $150 and not doing the flush or replacing the other components. Sure enough, contamination in the system caused the new compressor to fail in a matter of weeks. So even if I buy all the new parts myself, I'm looking at $750 in labor to have a shop do the install, flush, and recharge properly.
This was on a 2006 Pilot, so if there really is some other implication with a hybrid, which doesn't sound right to me, but either way I can see how at a dealership it could cost $2k plus.
Old Jun 14, 2017 | 04:50 PM
racer131's Avatar
that sounds about right. i don't work for on honda but i do work for mercedes and we are a lot more for the same work.
Old Jun 15, 2017 | 01:23 PM
ericwudi0830's Avatar
man thats how they getcha
carlove
Acura TSX
Jul 11, 2018 06:01 AM
RxRC
Honda CR-V & Element
Jun 27, 2016 10:23 PM
Draggin99Si
Dec 29, 2006 05:36 PM
slow99gsr
Jul 16, 2006 03:04 PM
