04 coupe window master switch help
Drivers window not operating.
Door was replaced, harness was spliced at master switch. Window motor removed, not working, revived by cleaning commutator/ brushes.
Have 2 extra switches from junk yard. All give same results .... 12 v on 3 of 4 motor leads, rather the 1 12v for up or 12v for down.
Have 2 switches disassembled, HELP
During last night testing of ground circui for contniuity, pin 14 Blk, didn't appear to go to ground and motor, just motor. Thought it might go to frame ground by center console, traced it and only wire pin 10 Blk goes back to G501 frame from door.
I went back and double checked the grounds. The black lead to the motor plug was not grounded . Created jumper to ground it and all three master switches are good and window operates. Yahoo.
Driver sw plug #14 blk was not grounded. Jumpered to #10 blk.
Previous owner had changed the door and cut the harness near window sw. In splicing it back together they missed this.
aresjay
Oct 17, 2018 01:36 PM
MyTardisIsMyCvc
Feb 12, 2015 01:15 PM
pwebb0207
Feb 6, 2011 09:13 PM
FOSHO
Dec 18, 2005 06:21 AM
