06 accord passenger windows stopped working
2006 honda accord. The driver window works however our passenger and rear power windows stopped. You can hear clicking in the door of the window you are attempting to roll down but no movement. Thanks Much ahead of time for any assistance.
Re: 06 accord passenger windows stopped working
if neither switch will operate the window then you need to pull the door panel off and look it takes less then 5 mins the motor could be bad which you can jump the motor and test it or it could be the regulator
it every window has quit working except the drivers i would pull the drivers panel off and check the switch but other then that take the door panel off of any door and jump the motor to make sure it's working but 3 windows going out at once is not usual
its the master switch, to verify this remove the master switch, with master switch still connected, run jumper wire from pin 1 to pin 3..
If you hear clicking then the regulator should be working. I would lightly try to push down a window slightly down while someone presses the button. It would be weird if all 3 regulators died at the same time. It could also maybe be a lack of power going to the regulators due to corrosion on the master switch from rain or moisture. Bottom line sounds like lack of power going to the regulator.
The same thing happened to my 2007 Honda Accord VP. One day, all of the windows, except the driver's side, quit working at the same time and you can hear clicking noises when you try to roll them down. This happened a couple of months ago in the middle of the summer. I am in Florida and it gets awfully hot here. Was there any solution to getting this fixed?
I also have the issue of the radio that just turns on and off at random times. It has turned on when the key wasn't in the ignition. Not sure if it still does that or not. Some days, it is very quiet in my car and other days, I get to randomly listen to music. Any suggestions?
Grace
Grace
pre90
06-09-2015 10:22 AM
hondagal2004
11-27-2013 07:55 PM
captainhecubus
08-20-2012 06:50 PM
