97 ex coupe best swap?
Old Jun 3, 2017 | 07:40 PM
scrubdakiller80's Avatar
Default 97 ex coupe best swap?
I'm going to swap my d16 its got 230 miles already Im trying to make it fast but I'm not trying to be disappointed and how much money do you think I'll spend on the swap doing it myself let me know I'll rather spend more money and make it fun than spend money and make it slow let me know what you think
Old Jun 3, 2017 | 07:57 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 97 ex coupe best swap?
Fast is subjective.
https://honda-tech.com/forums/honda-...tions-1998336/
Old Jun 3, 2017 | 08:59 PM
Lineman's Avatar
What is your future plans? Cheap swap is a ls swap ls trans. If you want a bit more performance then do b20z with gsr trans.
Old Jun 3, 2017 | 09:13 PM
Yea I was thinking a b series swap but I heard a lot of different types of series that I didnt know what would be the best and what will I need for a b20z swap?
Old Jun 4, 2017 | 12:23 PM
civic402lx's Avatar
Do the research. Find what fit your needs. Noone can tell you which is best for you. Only you can decide that. There are tons of info regarding swap. Some simple, most not. Decide your goal and budget, then start doing your homework.
Old Jun 5, 2017 | 05:47 AM
DanielP's Avatar
Adding on to what 402 said, we can't make your build for you. Do some research. If you want to push like 600hp do a gsr swap and boost it. If you want a good daily just do a b20 swap. Theres plenty of options, look around.
Old Jun 6, 2017 | 10:28 PM
What's the difference between a gsr and a b20?
Old Jun 6, 2017 | 10:38 PM
dsol's Avatar
like those guys said do your research and see what fits your budget and expectations. i have a 97 civic ex and my d series had around 240k on it before a head gasket failed. i opted for a b20 that i had given a refresh (water pump, timing belt, gaskets and a good cleaning). with that said my shell is pretty dirty, but i wanted something to take the daily beating but still have a little pep for fun.
cheap i would go with ls or b20. if your wanting something done fast then id look for another d series.
Old Jun 6, 2017 | 10:41 PM
Thats exactly what I wanted to hear what's a cheap transmission for a b20?
Old Jun 6, 2017 | 11:07 PM
eghatch9295's Avatar
Stancetard Hate Monger
b series transmissions are difficult, if not impossible, to find cheap these days. expect to spend double what a b20 costs on a good one.
Old Jun 6, 2017 | 11:08 PM
Ight thank you man god bless you
Old Jun 7, 2017 | 09:25 PM
NotARaCist's Avatar
...What? There are LS transmissions all over the place around here for $100-$200 in various states of repair. There are also a few on eBay in the $500 range. Transmissions also aren't too hard to fix, if you download the FSM and follow instructions properly.
Old Jun 9, 2017 | 07:32 AM
i didn't, and wouldn't recommend an ls transmission. better gear ratios/lsd in other transmissions make N/A cheapie engines like the b20 a whole lot more fun to drive.
Old Jun 9, 2017 | 08:17 AM
BryanM.'s Avatar
Resident Gearhead
With transmissions it's a roll of the dice. Unless you can drive a vehicle and know that it works.
Hmotors has them, although not cheap, but you can be certain you will get a good one. If they send you one that's not good, they will take it back and give you another.
Freemananana
17
May 29, 2014 06:58 AM
BrianB16A2
K Series
10
Jan 15, 2014 03:07 PM
matraca0997
15
Jun 3, 2007 08:34 PM
nationalracer
19
Jul 24, 2006 11:43 AM
awalk2005
Sep 13, 2003 09:04 AM
