Snow tires: Is wider really better?
Old Nov 10, 2002 | 02:10 PM
Old Skool's Avatar
Default Snow tires: Is wider really better?
I've heard mixed reviews about this. Anyone in for a good debate?
Old Nov 10, 2002 | 03:15 PM
CD8's Avatar
CD8
Default Re: Snow tires: Is wider really better? ( Foomanshu)
in snow, wider is not better. say you have to tires, 245s and some 195s. in the snow the 195s will give better traction because they will cut through the snow. the 245s will slide ON-TOP of the snow, which is not good. to slide. more narrow is better.
havent you ever seen the spiked skinnies on WRC cars?
Old Nov 10, 2002 | 04:04 PM
93accordEX's Avatar
Default Re: Snow tires: Is wider really better? (exaccord)
yea, narrower is better. for winter I have some 185's.
edit: right now I have these mounted on some steelies that I think are 5" wide, can I put these tires on my prelude rims, which I think are either 6 or 6.5" wide, don't remember.
[Modified by 93accordEX, 1:05 AM 11/11/2002]
GZERO's Avatar
i'll always tought that the narrow the tire is, the best the traction was on snow because of the WRC skinnies tires. Everytime i see them i laugh, cuz they are funny. I've seen that the same concept aplies to mud, the taller and narrower the tire is, the better is the traction.
Old Nov 10, 2002 | 04:43 PM
sauceman's Avatar
Default Re: Snow tires: Is wider really better? (GZERO)
That's right. Now you wouldn't necessaily want to go to extremes, because a tire surface too narrow would cause the grip on ice to become hazardous, unless your tires are nailed. Also, stability on dry surfaces is compromised if you put on tires that are too narrow. Ideally, for a 3rd gen, you wouln't go below 175's, and 185's for 4th, 5th and 6th gens.
Old Nov 11, 2002 | 03:12 AM
Hippie's Avatar
Default Re: Snow tires: Is wider really better? (sauceman77)
Exactly. Tall and narrow is the best for deep snow or mud (unless you;re a "mud bogger" ). But unless you drive in the deep stuff all the time it is best to compromise. 70 or 75 series tires on most cars work the best if you get a lot of snow and on light trucks up to an 85 series works pretty good. At least here in Illinois.
Best tire I ever had on ice short of studs or chains was a 70 series but I haven't tried any if the new "ice" compounds. I'm too cheap and we only get ice once or twice a winter on average around here. If it's too bad I just stay put.
[Modified by Hippie, 6:13 AM 11/11/2002]
Old Nov 11, 2002 | 05:28 AM
KGAccord's Avatar
Default Re: Snow tires: Is wider really better? (Hippie)
I used to run 185 65 15 studded snows, that accord was like a tank. The highway performance just blows though. I'm getting H-rated performance snow tires this season.
Old Nov 11, 2002 | 12:06 PM
Old Skool's Avatar
Default Re: Snow tires: Is wider really better? (KGAccord)
thanx guys, that really cleared things up for me
Spoonsinglecam
Nov 14, 2007 08:35 AM
Squad1
Honda Motorcycles
28
May 20, 2007 08:37 PM
aquarius
Mar 18, 2007 07:28 PM
TorquelessB16
Oct 4, 2006 05:14 PM
desync
15
Nov 5, 2003 03:33 PM
