Aem series1 1020 offline Issue
Old May 18, 2017 | 03:58 AM
G-power's Avatar
Default Aem series1 1020 offline Issue
HI everyone,
Same computer same USB to rs232 adapter i always i quickly connect my ems now start offline connection problem I can't connect but i have Aem serial Guage serial Guage work with Ems no problem. I format pc win10, win8, other serial USB adapter I try not connection always offline
Old May 18, 2017 | 12:35 PM
80%downtime's Avatar
Default re: Aem series1 1020 offline Issue
Run the AEM program in administrator mode. Also, update the drivers. Check AEM's website for the drivers. If that still fails, make sure that your ECU is grounded properly, otherwise it won't power up and you'll always get an offline connection.
Old May 19, 2017 | 03:49 AM
G-power's Avatar
Default Re: Aem series1 1020 offline Issue
Thank's for Answer, I'll control again all
Old May 23, 2017 | 06:34 AM
G-power's Avatar
Problem continues
I'll control ground ,USB serial driver ,other cable
Serial Guage work fine, car start no problem
Old May 24, 2017 | 09:51 AM
See if you have the proper drivers installed with no overlap from other drivers. Also, try different USB ports on the computer. I can't remember exactly how I did it, but I had this problem in the past and unplugging and replugging the USB during the ECU detection process did it for me.
Old May 25, 2017 | 05:51 AM
G-power's Avatar
Friend my labtop work only one USB port other 2 port die
Today I try other labtop I think my labtop problem
philafelman
Jul 16, 2009 05:40 PM
sportridermike
Honda S2000
May 26, 2005 02:56 PM
SpeedDreamz.com
Mar 18, 2004 07:51 PM
