Suspension & Brakes Theory, alignment, spring rates....
Suggestions Needed: 2017 Civic HB Sport Coilover Spring Rate for Daily Use
Old May 12, 2017 | 09:56 AM
joc217's Avatar
Default Suggestions Needed: 2017 Civic HB Sport Coilover Spring Rate for Daily Use
hi i have the new civic hatchback 2017 sport, weights around 2864lbs(1299kg) im trying to get a set of coilover but i want to know the best spring rate for daily drive this car comes with a 60/40 weight distribution, what would be the best fit for it? thank you
Old May 14, 2017 | 11:48 AM
spoolin2bars's Avatar
Default re: Suggestions Needed: 2017 Civic HB Sport Coilover Spring Rate for Daily Use
Best for a daily driver would be what's on it already. Took a dozen engineers thousands of hours of work to develop the suspension. If your not doing anything or racing with it why change it?
Old May 16, 2017 | 04:14 AM
joc217's Avatar
i totally understand your point and thank you, but im looking for a nice drop.
Old May 16, 2017 | 07:17 AM
cre8ive's Avatar
Research coilovers and find a decent set within your budget. Most companies will sell them with different spring pairings depending on the usage. Street setups will be softer, although expect a harsher ride over your stock setup, regardless of the springs.
Old May 16, 2017 | 07:40 AM
joc217's Avatar
ok thanks
joc217
Suspension & Brakes
May 12, 2017 09:55 AM
94BlueGSR
Suspension & Brakes
11
Mar 5, 2007 06:08 PM
neverness
Honda S2000
Jul 18, 2006 04:40 PM
Apex i ITR
Jan 27, 2003 07:54 AM
VegasHatch
Dec 30, 2002 04:32 PM
