Can't take key out of the ignition...
Old May 9, 2017 | 01:12 PM
RichterFry's Avatar
Default Can't take key out of the ignition...
1999 Civic CX
Every time I stop my car and put it in park, I can't get the key out of the ignition. When I turn the key back over, the dash lights indicate I'm in both Park and D4. It takes about 5 - 10 minutes of putting the car in and out of park to get the key out of the ignition. When I move the gear to D3 or 2, the dash light switches after maybe 2 seconds and I can hear a click coming from close to the glove compartment. Any recommendations on how to fix this? Thanks.
Old May 9, 2017 | 08:33 PM
tony_2018's Avatar
Fish Twig
Default Re: Can't take key out of the ignition...
gl, electrical issues...
Old May 9, 2017 | 09:10 PM
DieMaster's Avatar
Needs to be About 20% Cooler
to me it sounds like the gear selector switch but first check the basics; all the fuses are good and the grounds are sound.
Old May 10, 2017 | 02:48 AM
NVturbo's Avatar
O.G. triple O.G.
brake switch at the brake pedal. Had this issue before in my daughter's '97 Integra.
Old May 10, 2017 | 10:07 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I thought the brake switch controlled taking it our of park?
In which case I would think it would be related to the neutral safety switch of the gear selector not reading it's in park.
Possibly something as simple as corroded contacts.
Old May 10, 2017 | 10:50 AM
Neth's Avatar
I have this problem seemingly randomly on my del sol. it seems like there is too much play in the ignition and something isn't lined up right, if i jiggle it or pay close attention where it is when i start to push the key in to remove it, it works.
Old May 10, 2017 | 11:30 AM
RichterFry's Avatar
Not sure how to do all of that but I'll take a look at it with my father this weekend. He's a chrysler mechanic but I'm sure he'll be able to take a look. Having said that, I assume it's got something to do with the gear selector switch as well.
I apreciate the suggestion but I don't think that's it - I've never had trouble moving the car in and out of different gears/park.
I think if I pull up in the shifter while I put it in park it tends to work more often than if I don't? So I think it's got something to do with the actual gear selector mechanism.
Old May 10, 2017 | 11:49 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You really should see if you can locate the Factory Service Manual (FSM) for your car. Not the Haynes crap manual but the helminc.com manual. Please see the page below from the FSM for the 96-00 civic.
See page 23-131 and 23-132 in the Electrical section.
Old May 11, 2017 | 07:52 AM
NVturbo's Avatar
O.G. triple O.G.
At first, I thought it was the interlock module as well. Replaced the brake switch and it fixed the problem.
Old May 15, 2017 | 07:03 PM
DJBLUEB20's Avatar
Hi, I'm having a similiar issue any luck finding out what the problem was?
Old May 16, 2017 | 01:54 PM
RichterFry's Avatar
I took the car to where my father works (He's a mechanic), and he had no trouble with the key at all. So he hopped in the passenger side and I got in and I still couldn't get the key out (after turning on the car, reversing, putting it in drive and moving a bit, then putting it in park). So he grabbed the shifter, and it made a little click noise, and the key came out. So basically every time I want to take the key out of the ignition, I just need to wiggle the shifter ever so slightly when the car is in park. I guess slamming it hard in to park rarely gave me the same effect as that.
Old May 16, 2017 | 04:12 PM
agb22's Avatar
Im assuming your car is automatic? This is a common problem.
Key Cannot Be Removed From the Ignition Switch ('96-'99 with Automatic Transmission and Shift/Ignition Lock)
Shift cable is out of adjustment, preventing the pin from engaging in the key lock switch. Adjust the shift cable.
SEARCH FOR - TSB 97-009
I just did this for my daily civic the other day. Easy Fix.
Old May 16, 2017 | 05:03 PM
RichterFry's Avatar
Yep, that looks like it's exactly my problem. Thanks!
redbug2
Honda Civic (2001 - 2005)
Jul 7, 2014 10:41 AM
Steve LeB
Sep 2, 2012 10:15 AM
DRKSol
Acura TL, RL & ZDX
Dec 18, 2009 04:20 PM
AlxSiR7
Nov 25, 2004 02:12 PM
JToolz
Feb 15, 2004 06:56 PM
