Can't take key out of the ignition...
1999 Civic CX
Every time I stop my car and put it in park, I can't get the key out of the ignition. When I turn the key back over, the dash lights indicate I'm in both Park and D4. It takes about 5 - 10 minutes of putting the car in and out of park to get the key out of the ignition. When I move the gear to D3 or 2, the dash light switches after maybe 2 seconds and I can hear a click coming from close to the glove compartment. Any recommendations on how to fix this? Thanks.
Needs to be About 20% Cooler
1 Post
Re: Can't take key out of the ignition...
to me it sounds like the gear selector switch but first check the basics; all the fuses are good and the grounds are sound.
In which case I would think it would be related to the neutral safety switch of the gear selector not reading it's in park.
Possibly something as simple as corroded contacts.
I have this problem seemingly randomly on my del sol. it seems like there is too much play in the ignition and something isn't lined up right, if i jiggle it or pay close attention where it is when i start to push the key in to remove it, it works.
I think if I pull up in the shifter while I put it in park it tends to work more often than if I don't? So I think it's got something to do with the actual gear selector mechanism.
You really should see if you can locate the Factory Service Manual (FSM) for your car. Not the Haynes crap manual but the helminc.com manual. Please see the page below from the FSM for the 96-00 civic.
See page 23-131 and 23-132 in the Electrical section.
O.G. triple O.G.
At first, I thought it was the interlock module as well. Replaced the brake switch and it fixed the problem.
I took the car to where my father works (He's a mechanic), and he had no trouble with the key at all. So he hopped in the passenger side and I got in and I still couldn't get the key out (after turning on the car, reversing, putting it in drive and moving a bit, then putting it in park). So he grabbed the shifter, and it made a little click noise, and the key came out. So basically every time I want to take the key out of the ignition, I just need to wiggle the shifter ever so slightly when the car is in park. I guess slamming it hard in to park rarely gave me the same effect as that.
Im assuming your car is automatic? This is a common problem.
Key Cannot Be Removed From the Ignition Switch ('96-'99 with Automatic Transmission and Shift/Ignition Lock)
Shift cable is out of adjustment, preventing the pin from engaging in the key lock switch. Adjust the shift cable.
SEARCH FOR - TSB 97-009
I just did this for my daily civic the other day. Easy Fix.
redbug2
Honda Civic (2001 - 2005)
07-07-2014 10:41 AM
DRKSol
Acura TL, RL & ZDX
12-18-2009 04:20 PM
