95 civic engine swap
Old May 3, 2017 | 04:08 PM
Gary Howard's Avatar
Default 95 civic engine swap
Will an a20a1 fit? If so what do i need?
Old May 3, 2017 | 07:00 PM
x.l.r.8's Avatar
Default Re: 95 civic engine swap
The ability to use the search function and read FAQ's
Old May 3, 2017 | 09:34 PM
i cant seem to find this information anywhere
Old May 3, 2017 | 11:04 PM
x.l.r.8's Avatar
The engine mounts need to be made, notch the frame rails and crossmember, rad support throttle cable and shifter linkage, axles and put a 95 hp engine when a simple b16 is 140 is bolt in, this seems counter productive!
[QUOTEA20A1 2.0 12V SOHC 2bbl Carb 1955 98hp@5500rpm 109tq@3500rpm '87-'89 Accord DX/LX (USA)
A20A3 2.0 12V SOHC PGM-FI 1955 110hp@5500rpm 114tq@4500rpm '87 Accord LX-i (USA)
You'll get close to those numbers with a:
D15A3 1.5 8V SOHC PGM-FI 1488 91hp@5500rpm 93tq@4500rpm '87 Civic/CRX Si (USA)
or
D16A1 1.6 16V DOHC PGM-FI 1590 113hp@6250rpm 99tq@5500rpm '86-'89 Integra (USA) ][/QUOTE]
The reason you cant find any info is because its simply not worth doing. I have a TVRv8 in a 924 porsche so I know about conversions, and this ones a non starter.
Old May 4, 2017 | 08:00 AM
NVturbo's Avatar
O.G. triple O.G.
Why the hell would anyone want to put that motor in a EG Civic?? Seriously...why?
vicpacdo
Apr 8, 2012 09:45 AM
hopsta
Aug 23, 2004 12:09 PM
turbo4racing
Apr 8, 2003 04:56 PM
