Vehicle Speed Sensor Problem
Old May 2, 2017 | 10:47 AM
tsalindo's Avatar
Default Vehicle Speed Sensor Problem
I recently changed my Vehicle Speed Sensor in my '95 Honda Civic. Unfortunately, my speedometer still goes on and off intermittently. Checking the wiring to the sensor with the engine switch on, I see a bad ground connection (700 Ohms black wire) while the other hot wires +12V & +5V seem normal. How do I fix the ground problem if this is the issue with my speedometer?
Old May 2, 2017 | 12:22 PM
mk378's Avatar
Default Re: Vehicle Speed Sensor Problem
To get an accurate resistance measurement (and not damage your meter), the circuit must be dead.
With the key on and the sensor plugged in, there should be near zero volts on the black wire to engine ground and thus to battery (-). If not you will need to take the engine harness apart there are some splices of the black wires wrapped up inside it.
If the odometer rolls consistently and accurately, the sensor and associated wiring should be good, the problem would be the speedometer itself.
Old May 17, 2017 | 10:25 PM
tsalindo's Avatar
You're right and thank you, mk378. With the engine switch off, there is a good ground connection to the black wire. Additionally, from the wiring schematic, the Vehicle Speed Sensor(VSS) sends signals to the cruise control which functions normally. So, the VSS is okay. After removing the instrument cluster, containing the speedometer, and examining the soldering contacts and joints, there are no signs of loose connections. Therefore, the problem is just a worn out speedometer after 22 years of driving. So, I bought a good used speedometer with low mileage. To keep the car legal with the original mileage, I disassembled the broken speedometer and took out the old odometer and tripmeter assembly which still works. Then, I put it in the good speedometer - keeping the car legit. So far, the speedometer works fine and functions well.
Old May 18, 2017 | 06:03 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
From my experience and what I have seen, the jumpy speedo is usually the PCB board on the back of the speedo.
I had to replace mine with another used unit and I saw another thread around that time that they had the same issue and the fix was the same as mine. As well as one of the build threads, their speedo had issues and the board was the problem as previous owner had re-soldered trying to fix it.
It's pretty common it seems.
Old May 25, 2017 | 10:08 AM
04odyssey's Avatar
I downloaded GPSHud from Google play store installed on my phone Problem solved !
No need to replace or repair the speedometer or the odometer
Old May 25, 2017 | 05:53 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
This is very poor advise for the user or any future owners of the vehicle.
Sure you know roughly what your speed is and how far you have traveled but the the value of the car is significantly reduced just from the non working speedometer.
Please go troll else where.
Old May 25, 2017 | 08:56 PM
04odyssey's Avatar
Did you understand that my post was about a
​​solution in my case which I shared with others?
You're very literal, unable to differentiate between opinion, advice and/or tips.
"know it all" such as yourself are amusing, not to be taken too seriously.
Old May 25, 2017 | 09:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
​​solution in my case.......?​​​​​
Then shouldn't you be starting your own thread about your problem instead of hijacking someone else's thread with an opinion that has no technical merit for the car in question?
orlandoEM2
Mar 23, 2010 07:23 PM
IhateworkingoncaRs
Mar 22, 2010 10:17 PM
stevescivic
Audio / Security / Video
Apr 23, 2007 07:19 AM
downest
May 15, 2006 08:19 PM
HATCHMO92
Aug 8, 2004 02:09 PM
