CEL coming on, cant rev past 3500~ rpms, 95 ex
Old Apr 21, 2017 | 04:44 PM
Shollman's Avatar
Default CEL coming on, cant rev past 3500~ rpms, 95 ex
So ive noticed that after racing my car around, my cel will comes on sometimes. Usually after going pretty high into fourth my cel will come on and my car will not let me go passed 3500 rpms. I know I should get codes and whatnot... But the cel will go off if I turn my car off and back on and my rpms will be fine again. I think its my spool solenoid because to me the connection doesnt look the best and it gets pretty hot, not quite sure if its supposed to. Any thoughts or ideas on what I can do, I want to eliminate this problem asap, thanks.
Old Apr 21, 2017 | 05:17 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: CEL coming on, cant rev past 3500~ rpms, 95 ex
Check the code while it's on and running
Old Apr 22, 2017 | 02:46 PM
Shollman's Avatar
Is that ok to do? I have to unplug a couple wires and put a paper clip in ome to get he codes.. Id assume thats not safe
Old Apr 22, 2017 | 03:17 PM
mk378's Avatar
You don't unplug anything. Pull down the carpet on the right side panel of the car next to the blower motor. Find the little two wire plug that is not plugged in to anything, which is next to a little 3 wire plug that is not plugged in to anything. Jump the two wire plug. The 3 wire plug is for dealer test equipment only.
black0hatch
Honda CR-V & Element
38
Sep 18, 2012 08:22 PM
rhoades
10
Dec 28, 2009 12:42 AM
401RIguy
Mar 23, 2009 02:29 PM
PhantoM.DA
11
Jul 2, 2008 06:58 PM
Apex1972
Nov 3, 2006 08:18 AM
