98 Ex low speed jerking
I have a 98 EX with a swapped b16a/GSR head and when I'm not touching the gas pedal in 2nd gear at low speed/rpm in a parking lot for example it seems to jerk back and forth until I press the gas again. This is my first manual car, is this a normal thing or is there something wrong?
I'm not touching the clutch, I'm rolling in 2nd gear at about 7-10 mph in a parking lot and it bucks back and forth the entire time until I touch the gas again. It doesn't seem like its close to stalling either..
It could be TPS induced... improper voltage setting of the TPS could create the light-throttle "bucking" that you describe. Also, it could be in the tune if you have a tuneable ECU.
muddmonky
Apr 11, 2013 12:10 PM
EJeff8
32
Nov 13, 2010 08:32 AM
