tunning with chrome to pass state ref
Old Apr 18, 2017 | 06:30 AM
crookson speed's Avatar
Default tunning with chrome to pass state ref
so long story short my ecu has been chipped and my ref dosnt know. i can pass the visual. so far i am running open loop so i failed by a long run. but i live in a basic area so there are no rollers its just a basic 0 to 2500 idle test. if i tune it in open loop with a decent afr gadge to a afr that will get me to pass. then in wire in the o2 and run it in closed loop will i pass for sure. ihave a brand new 50 state cat and i also need to install a iat sensor as i have a resistor in the plug as of now. i am a noob i know this if someone can direct me to some information that will answer my question i would like that too i just cant find it on my own as in tunning for emissions. im just currently studing to learn how to tune our pgmfi
Old Apr 18, 2017 | 10:45 AM
Default Re: tunning with chrome to pass state ref
also sorry motor is a b16a with a chipped ecu in a 91 si with obd1 conversion repined the ecu clips and everything.
Old Apr 18, 2017 | 11:15 AM
spAdam's Avatar
Loved
Community Favorite
Fix your IAT before you do anything else. It's one of the four critical inputs for running the engine properly.
Old Apr 19, 2017 | 06:11 AM
ok lets say i install my iat and a o2 sensor can i pass or should i take the extra messure and dollars to get n afr gadge and tune my map. because i only want to go there twice.
Old Apr 19, 2017 | 04:15 PM
so i fixed the iat and im going to buy a chip burner so i can enable my o2. i also am going to get a aem wide band unless someone can convince me otherwise. what air fuel ratio will get me to pass 14.7? and also if i want to adjust fuel tables on chrome manually how do i know how far to bring the numbers down im having a hard time finding information on that. thank for the help.
Old Apr 19, 2017 | 06:12 PM
spAdam's Avatar
Loved
Community Favorite
If your engine is stock, you've wired everything correctly to the correct ecu, and you have a decent catalyst, you should be able to pass (without tuning). If your wiring is all jacked and you have a mish-mash of parts, you're going to have a tough time calibrating that out (by which I mean not likely)
Old Apr 19, 2017 | 06:44 PM
what if everything is okay but my evap solenoid valve not working
Old Apr 19, 2017 | 11:34 PM
80%downtime's Avatar
If you're going to use the wideband as an O2 and you're going to run off of a chipped ECU, make sure the wideband can support simulated narrowband output. PLX is just one of the many companies that make one.
You might want to check it then.
Old Apr 21, 2017 | 05:54 AM
You might want to check it then. https://www.youtube.com/watch?v=VmfiI1ribdM
thanks for the info just to clarify can i pass without a purge solenoid and can i tune my car in close loop to schive a desired 0 to 2500 afr in closed loop then run that map in open loop with a o2 sensor. im also at sea level btw.
Old Apr 22, 2017 | 01:06 AM
That's a question better asked to a Smog Tech. I've never tuned any of my cars to "pass smog", but here, have a reference.
Old Apr 22, 2017 | 06:55 AM
thanks alot dude for the help
Old Apr 22, 2017 | 07:01 AM
[QUOTE=80%downtime;51260920]If you're going to use the wideband as an O2 and you're going to run off of a chipped ECU, make sure the wideband can support simulated narrowband output. PLX is just one of the many companies that make one.
im guessing i should go with a wideband that supports narrow band because its more accurate in those volts? what makes it diffrent from a wide band if the wide band reads a higher voltage range.
Old Apr 22, 2017 | 10:57 AM
No. It's because your ECU isn't calibrated to the voltage output of a wideband. It's calibrated to the voltage outputs you'd normally see from a narrowband output. A narrowband only detects a small range of AFR; a wideband can detect a much wider range, hence their names. They both put out voltages from 0-5v. It's just that the voltage output from a narrowband to reflect an AFR isn't going to be the same as a wideband reflecting the same AFR.
Old Apr 25, 2017 | 03:30 PM
dude your a saint it is crystal clear to me now
asonoasono
Honda CR-V & Element
Jan 10, 2011 07:06 AM
B16Drag
Southern California
Sep 21, 2009 01:51 PM
sitrucjr
Feb 26, 2004 09:47 AM
hybrider
Apr 29, 2003 06:50 PM
G2Integrity
Jul 3, 2002 02:29 PM
