Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Engine fail accelerate
Old Apr 17, 2017 | 06:32 AM
thebet6's Avatar
Icon4 Engine fail accelerate
Good afternoon,
please I owned 2006 Honda Civic Coupe, if I should drive it for 14-15 minutes at 100-105km/h on high way, the vehicle will fail to accelerate again and the RPM will remain at 2,000rpm after placing the gear shift on Neutral, if I turn off the engine and wait for some minutes it will work normal again. i have replaced the electronic throttle body, change the temperature sensor but the problem still remain. please i need help.
Old Apr 17, 2017 | 11:18 PM
holmesnmanny's Avatar
Default Re: Engine fail accelerate
scan for codes
Old Apr 17, 2017 | 11:26 PM
thebet6's Avatar
Originally Posted by holmesnmanny
scan for codes
i scanned for code, and he asked me to replace coolant temperature sensor and I did but the problem still persist. Is it possible for the fuel pump or key battery low to be causing it, I discovered that the key battery is poor.
Old Apr 19, 2017 | 07:06 AM
DaveSi677's Avatar
The key battery is only going to affect how you get in and out of the car by unlocking or locking the doors.
Have you check the TPS sensor?
Old Apr 19, 2017 | 11:46 PM
scan for codes
Kenny Sorlie
Honda Civic (2001 - 2005)
Apr 16, 2019 10:18 AM
ESL Teacher
Jun 21, 2015 09:17 PM
accerat
Jan 14, 2015 10:19 PM
Stryk3r420
Jan 30, 2010 05:35 PM
jaredvabeach
Jan 20, 2009 05:59 PM
