2016 Honda CRV wont' start
Hi,
I am a new member as of 5 minutes ago. I have two Honda CRV's. My 2016 CRV does not start. It turns over but seams to be gasping for fuel. My first thought was the fuel pump was going bad. I tapped on the top of the fuel pump housing and the engine started but ran only a minute or two. It lacked power and struggled to stay on. I think the tapping of the fuel housing to get the engine started was not the fix because later I checked the 4 wires going into the connector at the top of the fuel housing and there was no dc voltage. Plus I never could hear the pump turn on. Therefore, I checked the 15 vamp fuse inside the car near the steering column and it is good. I can't find the fuel relay. I think this may be the problem. Does anyone know where the relay is? I have looked behind the glove box and under the dash in the steering column area. Once I find the relay can I test it or swap it with another like relay used on this car or should I buy a new one hoping it is bad? Any help would be appreciated. I like to learn and fix things myself.
John
John
stuckinhell
Mar 16, 2006 09:51 PM
2camsaam
18
Apr 13, 2004 03:47 AM
