help stuck in up with a dead honda
i have traced the problem to the pgm-Fi main relay. thinking it would fix it because i tried this trick on a dogde i jumped the relay so the fuel pump would turn on now that the fuel pump is functional the engine still wont fire any ideas. there is power come to the relay but not going to the fuel pump connectors 5 and 7 are hot and i have now installed a new main relay and it still wont fire up i have checked all the fuses and they all check out ok. the problem occured while we were driving down the road and the engine just shut off. we pulled over and the engine started up again ran for about 2 minutes then died again and wouldn't start back up after that i thought it was the fuel pump because i dissconnected the man feed line and had my gf turn the key to on engine off and no fuel was present then i checked out the fuel pump for power none was present so i went to the pgm-fi main relay where i found that power oin the yellow green was going in but not coming out
one other thing how come when i jump the service connector its the SRS light that blinks not the chk engine light?
Modified by stuckinhell at 10:51 AM 3/17/2006
Modified by stuckinhell at 2:24 PM 3/17/2006
Re: help stuck in up with a dead honda (stuckinhell)
sorry i cant help you...but you will probably get more responses if you give more details
(plus a free bump)
(plus a free bump)
