110k maintance
Let me start out by saying I'm not really new here, I haven't logged in or posted in at least 7 years. I forget my username and email I used for log in... With that being said, I am always on here reading threads and info, so here I go
I have already completed the 100k maintance items on my 08 CR-V ex-L, I have owned this car since mileage 3 and I think I keep up with all maintenance items: Oil is done on schedule, I do my AT fluid drain and fill every other oil change, differential when the minder tells me (I do not tow), same with the air filterS, alternator has been changed with belt and tensioner, battery also, brake fluid and power steering has also been recently changed, I just did the spark plugs and I let the dealer do the valve adjustment 2k ago, AC compressor was replaced by the dealer last summer under warranty....
So here is my question, I like to stay on top of things and change/fix before the problems happen. What items could I start working on this summer that I might have a problem with the next 20k? I plan on doing coolant without a doubt this summer, do I go ahead and do the radiator hoses, water pump and thermostat this summer? If so, do I throw in a new radiator also?(I remember my 94 integra back in the day needed a new one at 100k because chances were it was going soon) is it silly to replace the "low beam" headlight bulbs? It seems like they are not very bright anymore, they are the factory OEM bulbs that came from the factory! (I use to get high beam flashed when I bought the car because they were so bright, this hasn't happened in 8 years though...
What other suggestions do people have? I am so busy with work August to May, I like to get stuff done while I'm slow with work, even if it is preventative maintance.
Thanks in advance!
Thanks in advance!
Juan_Mitosis
Apr 27, 2009 03:42 PM
