Gas drain plug?
Old Apr 14, 2017 | 06:24 AM
76 camaro car's Avatar
Default Gas drain plug?
I finally have a little time to work on my 01 accord and was going to drain the 3+ year old gas from the tank. I have it up on jack stands and have search all exposed sides and the bottom of the tank and can not find a drain. The car has 3/4 of a tank of old gas in it I need to get out. Please don't tell me there is no drain on a 01. At the end of the day I have to put the car back on the ground so if there is a drain would like to find it before then. Any help is appreciated.
Old Apr 14, 2017 | 07:21 AM
Default Re: Gas drain plug?
I looked again and am almost certain there is no drain on the tank. How else can I get the gas out?
Old Apr 15, 2017 | 12:31 AM
holmesnmanny's Avatar
sounds like you're going to have to use a pump of some sort
Old Apr 15, 2017 | 05:31 AM
poorman212's Avatar
Use the fuel pump
Disconnect the fuel feed line - pick your spot. Set it so you can "catch" the gas. Hot wire the fuel pump.......done. Of course don't run the pump dry for very long.
Done
Old Apr 15, 2017 | 06:02 AM
After looking at it yesterday afternoon I think I am going to go in from the top of the tank by pulling the fuel pump out. Then I should be able to get the gas out with one of those cheap hand siphon pumps. It might take me awhile because there is at least 10 gallons in there. That way I do not have to worry about running the cars fuel pump dry or the possibility of clogging the screen. Just wonder how I am going to get rid of 10 gallons of 3 year old gas.
Old Nov 15, 2018 | 10:01 AM
Mateus Pires's Avatar
How did you do this? I have a lot of water in the tank and need to drain it. How do you get to the top of the tank?
Old Nov 15, 2018 | 04:33 PM
schreps's Avatar
Access cover in the trunk.... but instead of disturbing the fuel pump why not buy 10 ft of vinyl tubing (4 bucks) at home depot and siphon the water out.
https://honda-tech.com/forums/honda-...-leak-3329580/
https://www.homedepot.com/p/UDP-3-16...6004/304185145
Hondaisok
Sep 27, 2010 09:30 AM
FO SHO
Apr 11, 2010 01:30 PM
sc0braj
Aug 18, 2008 08:15 AM
Hard2Find
Aug 16, 2004 08:47 PM
liquid51
Nov 2, 2003 06:41 AM
