2000 Honda civic won't move.
I have a 2000 Honda civic hx 5 speed the ball joint And axle went out on the highway. I replaced both and the wheels now move side to side but the car will not move. Any help or comments would be fantastic
We just replacedthe inner CV axles it had broke off at the transmission but has been replaced it feels like its not going into gear. It fires right up and the wheels turn car just doesn't go anywhere
It sounds like what ^ said. i had that problem and only one halfshaft was popped in. it easy for one to pop out when putting the other one in. i cant remember what side it was when one was put in it kept popping the other out until i did it the opposite way.
The wheels move side to side but do not spin. I have a lot of money in the ball joints axle and tie rod ends and no one seems to know why its not moving as I said it feels like its not going into gear
OP: when you intsalled the CV axles did you hear them "click" in when seated properly?
Did you knock the inner splines in using the outer axle as shown in this video starting at 5:45 time mark?
I didn't put them in a mechanic did and he said they are in properly like I said its like its not going into gear it has a newer clutch could something have came loose with that when everything went out initially
Did the same mechanic do the prior clutch replacement you mentioned and how many miles ago was it replaced?
Does the speedometer go up when you put it in gear and try to move? If it does, that means the clutch is working but you have an axle problem.
"Axle broke off inside the transmission" would be a very unusual sort of failure. Usually either a CV joint comes apart or the axle breaks in the middle.
donnieb22000
Jun 17, 2018 09:12 AM
em1 legend
11
Apr 3, 2014 02:12 PM
tylerfromnj
Feb 7, 2012 12:14 PM
EM1OwnerSi
Mar 24, 2007 11:55 PM
