1996 ign lock cylinder interchangability
Old Mar 24, 2017 | 01:45 PM
Tachi's Avatar
Default 1996 ign lock cylinder interchangability
The dummy I am, I lost the only key I had to my car. I've written off finding it at this point.
I'm believing that my initial solution of a hidden interlock switch and just bypassing the key in favor of a switch and a button on the console are unwise. But at the same time I am having difficulty reconciling $250 for a new ignition switch, which has to be special ordered anyway.
I've seen the stock photos of the parts at work and the connectors and pinouts look the same between auto and stick versions, but the switches themselves look different. Has anyone seen the two side by side, and will the automatic version mount up? I ask because I'm contemplating going to the junkyard to look for one and finding one with a key in it will be a long shot and I would like to broaden my pool as much as possible.
Thanks for the time.
Old Mar 25, 2017 | 12:13 PM
jollyhonda's Avatar
Default Re: 1996 ign lock cylinder interchangability
Do you have the original owners manual for the car? If so look in the front and see if the information from the original sale is filled out...should be a key code written there. ANY good locksmith can cut you a key from that code. You can also see if your local honda dealer can provide the code and cut a new key. If you find a locksmith, they might be able to cut you a key if you can take them one of the door lock cylinders
Old Mar 25, 2017 | 08:19 PM
Tachi's Avatar
I am at /least/ the 4th owner of the car. That is long gone. My local Honda dealer is in the middle of Ann Arbor Michigan [high local wealth concentration], they're not interested in helping some young schmuck get parts for a 21 year old car. I'll look into the locksmith, the passenger side door lock is still serviceable. I'm not interested in cutting the ign switch out, but I am going to be bypassing it tomorrow just to get the car driving again.
Old Mar 26, 2017 | 12:51 AM
holmesnmanny's Avatar
1996 HONDA ACCORD 2.2L L4 Ignition Lock Cylinder | RockAuto
Pay special attention to how he removes the steering column bolts. It's sheer genius(no pun intended)
Old Mar 26, 2017 | 04:17 AM
Tachi's Avatar
holmes, thank you, I would have been stumped by those bolts, it didn't occur to me that there would not be hex head fasteners there.
Old Mar 26, 2017 | 11:03 PM
When you get the new ignition assembly the two bolts that come supplied with it have heads that break off after you get to a certain torque.
Old Mar 27, 2017 | 08:15 AM
Tachi's Avatar
Got a pair of new keys cut from the vin [had to wait for monday]. I did not know that was an option previous. Thank you to those who answered.
Old Mar 27, 2017 | 10:21 PM
jollyhonda did mention that option up above
fazalabbas
Jan 5, 2019 10:36 PM
Psychoteen101
Sep 4, 2013 11:08 AM
Bishop1976
Oct 3, 2012 08:31 AM
Barf Hat
Apr 3, 2012 07:44 PM
JohnnyEF
May 10, 2009 04:10 PM
