96 w/swap bogging out.HELP!
Old Mar 6, 2017 | 12:10 PM
Ekgirl_88's Avatar
Icon5 96 w/swap bogging out.HELP!
New to this but I have a 96 civic ex with a vtec single cam it drove fine when I got it a few days ago & then it started to bogging out and sputtering it had no power engine was weak even in neutral. My homeboy Fixed the wire to the iacv and then it drove fine again now today it's back to the same thing no power had someone look to see if the wire came loose again but they say it didn't so I'm lost on what tf is going on. It has 2 codes for o2 & knock sensors also.
Old Mar 6, 2017 | 01:49 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 96 w/swap bogging out.HELP!
D16Y8 should be the motor for your 96 EX.
If a D16Z6 block was put in, instead, there would not be provisions for the knock sensor that is on the back of the block of the D16Y8.
This could potentially put the car into limp mode.
If you have a D16Y8, you might check the wiring from the knock sensor to the ECU.
Old Mar 6, 2017 | 01:51 PM
Ekgirl_88's Avatar
Ok thanks I'll check that out
Old Mar 6, 2017 | 02:45 PM
mk378's Avatar
Read the codes again. The problem with driving with the CEL on all the time is you can't tell when a new code is thrown. Also you get lower mpg and limp mode. So you should have all the sensors fixed so there are no codes.
Old Mar 6, 2017 | 02:48 PM
Ekgirl_88's Avatar
Ok I got the code read right after it started acting up and once my homeboy fixed the wire it was back to driving normal again check engine light still on for the knock & o2 sensors. But I'll get those changed and go from there.
Hoghunter25
19
Mar 2, 2016 10:24 AM
marsvolta1fan
Oct 18, 2012 01:24 PM
firstswap
Nov 10, 2009 05:58 PM
redsohc101
Dec 7, 2006 04:40 PM
96CIVICEX
Mar 27, 2004 02:29 AM
