JRSC build recommendation
Good evening all!
I'm in the market to rebuild my bottom end of my b 18th and would love some recommendations.
the current set up is a stock b18th with:
passworjdm whale intake
kamekazie header
Hytech true 2 1/2 exhaust
ex 440 injectors
68 mm throttle boddy
Jrsc supercharger
crv pulley boosting 100 a
I was making 232 on a dynapack sync before adding the kamekazie header and hytech exhaust.
last time at the track I was burning almost a quart of oil per session and realized it's time for a rebuild of the bottom end.
the short block is already at the machine for an inspection and a build. I would like to know if I should be changing pistons and compression and if so what is recommended. Along with the short block being rebuilt I will also be adding a LHT intercooler and heat exchanger. Any and all recommendationsorts is appreciated. Thanks
kamekazie header
ex 440 injectors
Jrsc supercharger
I'd recommend you check the jrsc thread.
I'm having trouble with my LHT manifold leaking currently - and while they'll fix it, it's still a pain in the *** to r&r and ship back and forth.
I second the water / meth injection, however.
