ehaust and header for JRSC?
Old May 12, 2005 | 01:25 PM
ME SO FST's Avatar
Default ehaust and header for JRSC?
Does anyone have any experience with the right header and exhaust for a B18C1 with a JRSC? I dont know if i should put on something big like a 3in or just the normal setups. I was looking into getting the full Mugen header all the way back. or even like a Apex WS or something with like a DC header. Please help me out.
By the way, the car is a 96 civic hatch with a gsr swap and JRSC.
Old May 12, 2005 | 01:36 PM
5litereater's Avatar
Default Re: ehaust and header for JRSC? (ME SO FST)
i know with turbo cars you want as little back pressure as possible. im pretty sure the same principles apply to a supercharged car. forced induction increases power through all rpms, but USUALLY your biggest gains are seen in top end. if you run a larger exhuast (particularly a 3"), you will definately see some noticable gains in your top end. just my .02 but i figured id try and steer ya in the right direction. good luck
Old May 12, 2005 | 01:40 PM
ME SO FST's Avatar
Default Re: ehaust and header for JRSC? (5litereater)
yea that is kinda what i was thinking but wasent sure with a superchager since its not like a turbo which runs off the exhaust. so you think i should run something like a 3in exhaust? what about for the header, that is still going to resrict since i know that not many companies make there headers big.
Old May 16, 2005 | 05:11 AM
ME SO FST's Avatar
anyone one else know?
Old May 16, 2005 | 07:41 AM
rmcdaniels's Avatar
I just used the Kamikaze with my JRSC. Here's some info:
http://www.theoldone.com/compo....html
It's cheap and it worked okay on my setup. There's probably better stuff out there if you have $1000 to spend.
Old May 16, 2005 | 09:52 AM
urbansi's Avatar
Default Re: ehaust and header for JRSC? (rmcdaniels)
1 peice headers>2 peice headers. the only nice thing about 2 peice is that their easier to put in. other than that they blow gaskets, and add extra weight.(like it really matters, but still.)
Old May 16, 2005 | 11:24 AM
illi Adik's Avatar
Default Re: ehaust and header for JRSC? (urbansi)
If the exhaust being rather loud doesnt bother you then I would run the Kami 2.5'' w/ a Thermal 3''. That is the setup I ran and althought a little loud it freed up a great bit of power. My setup was on a built motor and an 11psi pulley, if your setup isnt that drastic then 2.5'' will be sufficient.
angryhillbilly
Feb 10, 2015 10:43 PM
sloweg6
Jan 1, 2004 12:14 PM
HYREV2NR
Dec 28, 2003 09:59 PM
stnwag0n
Sep 16, 2002 01:42 PM
