252whp 180ft/lbs with stock type r Head and cams
Old Feb 19, 2017 | 01:19 PM
Allmotorpride's Avatar
Default 252whp 180ft/lbs with stock type r Head and cams
85mm GSR block sleeved by RS
Type R crankshaft knife edged by RS
ARP main studs
Eagle rods
ARP big bolts
Arias 12.5:1 compression pistons
Arias piston rings
OEM Type R/GSR oil pump, bored and shimmed
ATI super damper
Moroso 4 quart oil pan
Toda timing belt
Stock 97 JDM ITR head and cams from hmo
Cometic head gasket
ARP Head studs
Edelbrock Victor X intake manifold port matched to a
Skunk2 70mm throttle body
Hondata thermal intake manifold gasket
Knock off Bisimoto V2 header
Custom 3" exhaust
Skunk2 pro series cam gears
AEM fuel rail
Edelbrock fuel pressure regulator
Bosch 550cc fuel injectors
Hondata S300 tuned on E85
252whp 180ft/lbs
I don't know about you guys, but I certainly wasn't expecting these numbers! Have had this motor in my eg hatch for almost a year now, with just over 3000 miles on it. Motor was built and tuned by a reputable shop in my area.
Old Feb 19, 2017 | 02:02 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: 252whp 180ft/lbs with stock type r Head and cams
ARP main studs
Eagle rods
ARP big bolts
Arias piston rings
ATI super damper
Toda timing belt
Cometic head gasket
ARP Head studs
Custom 3" exhaust
AEM fuel rail
252whp 180ft/lbs
That's pretty dope. You should post this in the All Motor section.
Old Feb 19, 2017 | 02:51 PM
I posted it on the all motor dyno thread last July.
Old Feb 19, 2017 | 10:14 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
This doesn't actually appear to be a build thread as the motor is already fully build and been running for a significant amount of time already.
This appears to be a braggart thread as far as I can tell.
I am trying to figure out how this qualifies as a technical thread.
To me, this is no different than posting a pic of a refinished painted car. Those don't meeting this sections requirements, so I am confused how this would.
Can someone enlighten me why this thread would be acceptable over any other showing off thread?
Not to knock the build, but it's done now so doesn't fit the bill imo.
Old Feb 20, 2017 | 08:29 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Jesus Christ lol, anyone with half a brain knows this is fake.
This would be impressive numbers on a motor with cams, a ported head, and a good parts selection.
There is literally NO way that you made those numbers on a non-ported ITR head with ITR cams.
Nope. Zero chance.
Old Feb 20, 2017 | 01:54 PM
Sorry, new to posting threads.
Old Feb 20, 2017 | 01:57 PM
Nope. Zero chance.
Yeah I expect a lot of people not to believe it, this is the Internet after all. I wouldn't believe it myself if I didn't buy every part. It's real and a beast!
Old Feb 20, 2017 | 01:59 PM
DWP_Racing's Avatar
Nope. Zero chance.
Coming from the guy who said making 200whp all motor on a b16 is easy. So please explain how this cant be possible especially when you said 280whp all motor on a 2.0 liter is easy. 250whp for 85mm with his supported mods seems possible to me
Old Feb 20, 2017 | 02:01 PM
DWP_Racing's Avatar
also each dyno gives different numbers
Old Feb 20, 2017 | 02:08 PM
Very true. I should get it on another dyno. It's Definitely close though, because it's way meaner than my last setup that made 215whp and 140ft/lbs with Toda vtec killers.
Old Feb 20, 2017 | 02:09 PM
DWP_Racing's Avatar
what fuel are you running?
Old Feb 20, 2017 | 02:11 PM
DWP_Racing's Avatar
I guess if I could read id know it was e85... lol
Old Feb 20, 2017 | 02:53 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
We'll side on the benefit of the doubt and assume this is legit.
However, this still does not qualify as a tech thread so I struggle with leaving this when nice paint job threads are shunned by the community.
OP, if you want to document the build itself, by all means do so. I don't know how easy that will be after the fact but if you kept photos and documents and such to support a build, then by all means share.
I would suggest you take a look at the rules sticky above to see what qualifies and what does not in this section. And then do a quick search on build threads to get an idea if you could document after the fact with the material you may still have.
For now, this thread is closed. I do thank you for sharing. Regards.
Joecivic94
Apr 4, 2017 06:33 PM
chickenbandit
Oct 7, 2014 09:00 AM
slick1851
Jul 24, 2010 03:05 PM
DAteggman
Feb 13, 2008 09:37 PM
