Help with BWR catch can
Old Feb 13, 2017 | 08:14 PM
lolv8s's Avatar
10 Year Member
Default Help with BWR catch can
ok I've had two 10AN fittings welded into my valve cover. And I'm seeing how the other side of the catch can runs to where the PCV valve is located. And there are two fittings that they thread on to. Does the BWR kit come with those fittings or just the parts that thread on to them? And do the fittings need to be welded on to the back of the block or do they thread into the block where the PCV valve would go? I've searched for a how-to or pictures and I'm having trouble finding something descriptive. I posted this thread about the BWR catch can in hope that someone would link me to a how-to. Or post pictures. Thanks guys!!
Old Feb 16, 2017 | 10:09 PM
lolv8s's Avatar
10 Year Member
Default Re: Help with BWR catch can
bump
Old Mar 7, 2017 | 09:57 AM
lolv8s's Avatar
10 Year Member
bump
Old Mar 7, 2017 | 02:36 PM
tony_2018's Avatar
Fish Twig
You a vacuum source or else it's just going back to the block if you thread it in the back of the block.
Old Mar 14, 2017 | 02:31 AM
lolv8s's Avatar
10 Year Member
there are four fittings in the catch can block. so Its two in the valve cover. the other two have to go to the back of the block in place of the pcv valve I assume?
Old Mar 14, 2017 | 04:32 AM
ShinsenTuner's Avatar
No Jodas
The two that go to the back of the block are threaded into these types of adapters/block fittings. They go in place of where a pair of plugs would otherwise be. Notice there are three red items. The bottom larger blockoff/circle to the bottom right of the oil filter is the plug that will go where your old black PCV box used to be. These fittings are made by several companies, BWR being one of them.
Old Mar 16, 2017 | 04:08 AM
lolv8s's Avatar
10 Year Member
great picture!!! Thank you!!! In the BWR kit I bought it came with all of those fittings. But the bottom plug one just had orings like a cam seal. Will that be enough to hold it in place? And is there any order on the 4 fittings to the BWR box? Like valve cover to the top two and the block to the bottom two? Will I be ok running stock all motor with a BWR box? I want to put some miles on my engine (full build) before I boost it.
Old Mar 16, 2017 | 04:45 AM
tony_2018's Avatar
Fish Twig
Teflon tape
Old Mar 16, 2017 | 08:41 AM
No Jodas
The bottom plug that looks like a cam seal will probably be fine the way it is. If you think about the old unit, it doesn't house any fluids or anything and is held on in a similar fashion. If you're really concerned, you could use Honda Bond as a precautionary measure I suppose. But that's overkill IMO.
I also do not believe there is an order on the BWR box because it is not a "return style" catch can setup. I would just put them where they fit best with routing things through your engine bay. You won't have any negative impact from running the box with an OEM motor at all. Good luck with everything.
Old Mar 17, 2017 | 01:06 AM
lolv8s's Avatar
10 Year Member
Teflon tape
great idea actually lol
Old Mar 17, 2017 | 01:10 AM
lolv8s's Avatar
10 Year Member
ok thank you. I'm paranoid it might fall out. Might use just a little Honda Bond. Thank you!!
Old May 31, 2017 | 04:50 AM
lolv8s's Avatar
10 Year Member
ok I wanna ask here and make sure before I waste my time. I have a b18a1 block Im working with. But do I need to unscrew the green plug or the black two prong plug on the left? The two plugs are next to each other on the left.
Old May 31, 2017 | 05:05 AM
lolv8s's Avatar
10 Year Member
I also question what do I do with the plug that the top of the PVC valve plugs into? (Circled in red)
Old May 31, 2017 | 08:05 AM
ontariorider's Avatar
I bought 2 ports from Honda oem that replace the black box thing for running a catch can on my b20vtec. VC is ported and back of the block is ported..just so a search the part number should pull right up.
Old May 31, 2017 | 03:54 PM
lolv8s's Avatar
10 Year Member
yes but where exactly is it ported? Can you post a pic?
Old Jun 1, 2017 | 06:59 PM
lolv8s's Avatar
10 Year Member
is one of the ports on the back of the block the vacuum source?
Old Jun 6, 2017 | 08:13 PM
lolv8s's Avatar
10 Year Member
anyone?
TravisBiggie
Jun 23, 2012 07:40 PM
blackeg
Apr 5, 2011 04:48 AM
kielcivic
Jun 11, 2009 02:57 PM
Cyphear
Dec 29, 2008 02:07 PM
djtsmith007
Apr 23, 2007 08:29 PM
