Which Turbo would make more power?
Performance TX-60-62 Turbocharger 85 a/r (T3 flange / 4 bolt exhaust)- | eBay
specs:
Compressor inlet : 4.00" inch
Compressor outlet 2.50" inch
Compressor cover : tx-60 cover
Compressor Wheel diameter: 58 mm / 76mm
Turbine wheel diameter : 62mm / 70mm
Exhaust trim: 85 a/r
Turbine flange type: t3 flange
Downpipe flange type : 2.5" 4 bolt exhaust flange
Cooling type: oil cooled only
Horsepower rating: 300-600 hp+
or
Rev9Power TX-Series Turbocharger TX-66 Turbocharger .85 A/R T3 / 4 Bolt Exhaust | eBay
Specs:
or
T3 flange GT35 GT3582 universal A/R .70 Anti-surge turbo turbocharger rpw | eBay
specs: CompressorTrim56Inducer Diamter61.5mmExducer Diamter81.5mmA/R0.7Blades Number6 doubleTurbineTrim84Inducer Diamter68mmExducer Diamter62.4mmA/R0.63Blades Number10 double
From my math the "6062" is a 58trim on the compressor but what i dont understand is the TX-66 (last one) seems to have the bigger compressor wheel but is a smaller trim? sorry for the noob question...
dont flame for the eBay turbos.
specs:
or
Specs:
Compressor Inlet
4.00 inchCompressor Outlet
2.50 inchCompressor Cover
Anti-Surged 70 Series CoverCompressor Wheel Diameter
65mm/91mmTurbine Wheel Diamete
62mm/70mmExhaust Trim
85 A/RTurbine Flange Type
T3 FlangeDownpipe Flange Type
2.5" 4 Bolt Exhaust FlangeCooling Type
Oil CooledHorsepower Rating
300-600 HPor
Then don't throw them up here for comparison. (I'm sorry to be an *** about this, but) just because you see half-assed measurements that they give you, doesn't mean it can help speculate what the airflow rate of the turbo is. You gotta take that plunge down that rabbit-hole for yourself. I'll simply say this.
Look to what each of the measurements mean, (if they are even stating them accurately) and make that decision.Typically, the larger turbocharger makes more airflow. Compressor wheel deals with behaviour, turbine wheel deals with top end power capability.
If you need diagrams as to the components of each, let me know, I'll post them up. But you must make that final decision.
ebay turbos are natoriuos for lying about the specs, or the guy in china that made it really doesent know how to measure the wheel take you pick. Theres some tear downs on youtube that prove this. I.E they seem to think a 56mm wheel size is a 56 trim.
expect it to be smaller then what they say it is other then that its hit and miss like shodan said different results from different sellers.
Going of the info provided the first two should be about the same as the exhaust wheel and turbine housing are listed as the same specs
There's a guy with a couple holset hx40s for sale on the classifieds for forced induction. They're capable of about 650-700 wheel, and cost only a couple hundred bucks (ones a brand new rebuild)
In general, these turbos are cheap, plentiful in supply (hence cheap), very high performing and last hundreds of thousands of miles on the Oem trucks they commonly come from.
Tldr; for a slightly higher price, you can have a cheap turbo that will not only outperform on the dyno, but will also likely last a couple dozen times longer than any China charger
Your choice though of course
A) find another holset, they're very common and I'm fairly certain there are larger sized ones without divided housings
or
B) Just buy enough another housing, pretty sure they're all over ebay :p
BoBaFreak
Dec 3, 2008 07:25 PM
