Purge & pressure cut-off solenoid valve ??
Old Feb 6, 2017 | 07:52 AM
Fina-stof's Avatar
Default Purge & pressure cut-off solenoid valve ??
If i remove those 2 solenoid valves,
and all the surrounding hoses from them ?
will my engine run differently, or give me problems ??
Old Feb 7, 2017 | 12:49 PM
Bently_Coop's Avatar
Steve at Heart
Default Re: Purge & pressure cut-off solenoid valve ??
Do you have a throttle body with a MAP sensor on top? If the answer is no then yes.
You can remove the purge valve, map sensor and charcoal canister if you have a MAP sensor mounted on the throttle body.
Old Feb 7, 2017 | 02:41 PM
4drEF's Avatar
Keyboard Humorist
Your engine won't run different with the charcoal sensor delete, however it will not be helping the environment.
There is a line from the charcoal canister that goes to the fuel tank to collect fuel vapors.
Under certain circumstances when the engine isn't doing much, the ECU opens up the purge cut solenoid to introduce those collected vapors to combustion.
If you delete the canister, you are supposed to leave that hose open to atmosphere so pressure doesn't build up in your fuel tank (unless you have a fuel cap that is truly vented).
Pressure build up will be obvious as simple as having the car parked in the sun on a hot day.
Also, the fumes coming from the tank will need to go somewhere. Don't be surprised if you smell them in your cabin or in a closed garage.
Old Feb 8, 2017 | 02:46 AM
Fina-stof's Avatar
The MAP is needed that i know 😜
Purge can go 👍🏼
Pressure cut-off ?? On b16a2 there is also none
it goes straight to the intake manifold
why on a b16a1 is there a valve in between ?
iainuts
Sep 20, 2008 10:23 AM
shaggyeg6si
May 15, 2008 07:48 AM
slither
Sep 20, 2005 10:33 AM
civic-si-2000
Mar 3, 2005 06:07 AM
thashadow
Jun 12, 2002 11:35 AM
