Does a bad O2 sensor make the AIT sensor bad too?
Old Jan 31, 2017 | 11:32 AM
Kodyc's Avatar
Post Does a bad O2 sensor make the AIT sensor bad too?
Old Jan 31, 2017 | 11:54 AM
mk378's Avatar
Default Re: Does a bad O2 sensor make the AIT sensor bad too?
Car info?
If it's a 1996-2000, the well known "fuse 15 problem" will cause several sensor codes to appear because the sensors aren't getting power. None of the sensors are actually bad.
Old Jan 31, 2017 | 12:25 PM
Kodyc's Avatar
It's a 95 Honda Civic EX
Old Jan 31, 2017 | 04:43 PM
m90polk1's Avatar
No the o2 has a heater and signal coming from the ecu, the intake air temp sensor (I believe that's what you meant ) is supplied voltage and is a potentiometer to change voltage signal back to the ecu based on temp. So it would not make the IAT bad.
Old Jan 31, 2017 | 05:45 PM
Kodyc's Avatar
OK thanks, just wandering because I replaced it about a year ago and I didn't think it would go bad that fast
Old Jan 31, 2017 | 05:50 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
First, what CEL codes are being displayed?
You sound like you are just shotgunning the problem, which is never cheap nor easy.
Old Jan 31, 2017 | 06:02 PM
Kodyc's Avatar
It's doing one long blink which I looked up and it said it's #10
​​​​the IAT sensor
Old Feb 2, 2017 | 03:40 PM
slomofo's Avatar
GDD Member
I've never seen an intake air temp sensor go bad before. I've changed a ton of them because people break them when putting engines in the car, but I've never seen one go bad on it's own.
Just throwin that out there.
Old Feb 2, 2017 | 04:05 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Maybe it's dirty
Old Feb 3, 2017 | 11:14 AM
Kodyc's Avatar
I took it off it looks fine but the code is still coming up.. is there anything else I can do?
Old Feb 3, 2017 | 01:04 PM
CX-Adam's Avatar
talks to himself
Community Builder
Per the Helm manual
  1. Reset the ECU
  2. Does code reappear?
  3. If yes, turn the ignition off
  4. Disconnect the 2P connector on the TA sensor (IAT)
  5. Measure the resistance between the two terminals
  6. Did you get between 0.4 and 4.0 kilo Ohms?
  7. If no, replace the sensor.
  8. If yes, turn the ignition on
  9. Measure the voltage between the Red/Yellow (+) wire and a BODY ground.
  10. Is there 5V?
  11. If yes, measure the voltage between the Red/Yellow and GRN/WHT terminals. If you get 5V, substitute a known good ECU. If you don't get 5V repair the open in the GRN/White between the ECU D22 and the IAT.
  12. If no, measure the voltage between D15 and D22 on the ECU (this is normally done with a test harness but you can push paper clips behind the wires into the plug)
  13. is there 5 volts?
  14. If No, replace the ECU with a known good ECU.
  15. if Yes, Repair open/short in the Red/Yellow wire between the ECU (D15) and the IAT
aw1234dude
Jun 25, 2007 09:57 AM
Perfectionist
Oct 20, 2006 03:36 PM
Ri5e
May 17, 2006 08:23 AM
Civicman86
Apr 30, 2006 02:20 PM
ashleeb
Aug 9, 2004 07:38 PM
