94 honda civic ex, radiator smoking
The plastic tank of the radiators are known to crack. It's a very common and well known issue. They last quite a long time but still, not forever.
It's the most likely culprit based on your description.
pretty sure that's what it is to cause last time I jacked front end up wasn't paying attention got on the radiator support with out realizing it and when I let it down the radiator dropped and was hanging so that's prolly what happened fault on a noobish mistake
If it's automatic (why don't people post even this most basic of car info), you will need to disconnect and reattach the transmission cooler lines. Manual cars just have the two big coolant hoses on the radiator.
I like to take out the radiator fan first, then R&R radiator.
It's the nature of the beast. As is repeating answers, no searching, not being aware of the FAQ etc etc.
You can direct users to the sticky at the top of the forum:
https://honda-tech.com/forums/honda-...sting-3002401/
Ron created a very informative guideline for new users to become aware.
It's better to replace them a long time before any holes appear. If they feel squishy or are "ballooned" out-- swelled to a larger diameter in the center than at the ends, replace.
98accordv6green
Jun 5, 2007 05:37 PM
