Suggestions Welcome: GSR OEM Oil Cooler is "clogged". Solutions?
Old Jan 18, 2017 | 02:46 AM
carlos8's Avatar
Default Suggestions Welcome: GSR OEM Oil Cooler is "clogged". Solutions?
Hi, My turbo ls Vtec oil cooler is clogged. There's any DIY way to unplug it or I need a new one?
Stock GSR oil cooler between block and golden eagle sandwich plate.
Old Jan 18, 2017 | 08:17 AM
TheShodan's Avatar
Moderator
Default re: Suggestions Welcome: GSR OEM Oil Cooler is "clogged". Solutions?
Clogged with sludge from a blown HG? or some other material?
Typically, you drain the coolant (probably needs to be flushed anyway), remove the cooler, clean out, reinstall, new coolant....
Until more detail, not sure what more you need to do anyway.
Old Jan 18, 2017 | 08:55 AM
carlos8's Avatar
No with sludge it's plugged badly. With one hose connected in whatever of both sides the water not come from the other, I let it sit with degreaser the whole night and nothing. I believe it was clogged when i buy it for $20.
Old Jan 18, 2017 | 10:04 AM
TheShodan's Avatar
Moderator
You may have to either "dig out" the physical clog, (which is actually more time consuming and worse) or, see about replacing the rubber hoses that attach to the oil cooler. If it's the metal portions where the hose connects, you have to dig it out.
This is kinda why we replace them with Laminova or air-to-air coolers. The OEM ones did very little for cooling oil. .
EJ8Squad919
Jun 7, 2013 12:51 PM
JW racing
46
May 25, 2012 06:13 AM
EG6 Love
Jan 19, 2010 07:39 PM
Dartanian
May 23, 2006 10:32 PM
