OEM Oil Cooler Question
Old May 22, 2006 | 06:48 PM
Dartanian's Avatar
Default OEM Oil Cooler Question
I have had a spare OEM GSR oil cooler chilling in my garage for the last 6 months and I want to put it on since my oil temps are a little higher than I would like.
What I am wondering is if it is possible to hook the water lines up from another similar sized hose like the water outlet on the intake manifold instead of buying an OBD1 water pipe.
Could that be a problem since coolant may be flowing from the block and is too hot?
Old May 23, 2006 | 02:01 PM
Dartanian's Avatar
No one has hooked up an OEM oil cooler on a car not equipped with it from the factory using different routing than through the water pipe?
Old May 23, 2006 | 09:03 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: OEM Oil Cooler Question (Das Schmoo)
run the heater hose off the thermostat housing to the cooler, then off the cooler into the intake or side of the head. basically just put it inline with one of the right sized heater hose.
Modified by not so civic at 10:24 PM 5/23/2006
Old May 23, 2006 | 10:18 PM
Dartanian's Avatar
Default Re: OEM Oil Cooler Question (not so civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic &raquo;</TD></TR><TR><TD CLASS="quote">run the heater hose off the thermostat housing to the cooler, then off the cooler into the intake or side of the head. basically just put it inline with one of the right sized heater hose.</TD></TR></TABLE>
That is the hose I was eyeballing when I was thinking about putting it in. Thanks for your help.
Old May 23, 2006 | 10:32 PM
carlos8
Jan 18, 2017 10:04 AM
JW racing
46
May 25, 2012 06:13 AM
mtownsi
Apr 25, 2007 07:56 AM
tilt
Mar 4, 2005 08:59 PM
