CEL Light Socket issues?
Old Jan 1, 2017 | 03:11 PM
EKhatcherr's Avatar
Default CEL Light Socket issues?
I recently purchased a 97 CX civic. the car is decent but I recently realized that the CEL bulb does not light up and I need it to light up on ignition in order for it to pass the smog inspection. I tried rotating the working bulbs into the CEL socket and nothing. I got another cluster(EX) and the same issue happens. I've tried buying a new bulb from autozone and I get nothing. The way I see it either both cluster have a bad CEL socket or maybe there is a wiring issue? Anybody ever had an issue with this before?
Thanks in advance
Old Jan 2, 2017 | 09:34 AM
EKhatcherr's Avatar
Default Re: CEL Light Socket issues?
So I hooked up my wife's CRV cluster and I still had no CEL light. So it turns out that there might be a fuse problem or a wiring issue. Anybody have any info on what could cause the CEL to be cancelled out or not work?
Old Jan 4, 2017 | 09:18 AM
motoxxxman's Avatar
sounds like someone before you had a problem and cut the cel wire so they wouldn't have to stare at a cel all the time. Seems now it's time to do some wire chasing.
Old Jan 4, 2017 | 09:27 AM
EKhatcherr's Avatar
I was afraid of that. I didn't know there was one specific cable that leads to the CELs function. a buddy of mine was saying that maybe my ecu was going bad but don't get you get other issue with that?
Old Jan 4, 2017 | 08:53 PM
motoxxxman's Avatar
when the ecu goes bad, it will either throw a solid cel that is on 100% of the time, of a code zero which means no cel at all. usually a code zero will throw the cel on though when the service connector is not jumped, and no cel when the service connector is jumped. no cel ever is usually a cut or broken wire. and yes, it's one single wire from the ecu to the dash cluster plug who's only function is to illuminate the cel.
hatchmanej6
16
Aug 14, 2013 12:48 PM
SPOOLINmatt
Engine Management and Tuning
Dec 9, 2009 03:02 PM
O16581724 5 2 5
Nov 16, 2005 04:26 PM
CA6VTEC
Aug 14, 2004 01:13 AM
