94 honda del sol jdm b16 swap (evap canister)
Old Dec 24, 2016 | 07:13 PM
smokescreen160's Avatar
Default 94 honda del sol jdm b16 swap (evap canister)
Hello i was wondering how my usdm evap canister should be hooked up, right now the nipple that would go to the purge valve is going to the tb nipple and the 2nd nipple on the canister right above the other is also going to another TB nipple motor is a sir2 jdm b16a motor. Ive done a ton of research just don't get what I'm supposed to do. Thanks
Old Dec 25, 2016 | 10:36 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Default Re: 94 honda del sol jdm b16 swap (evap canister)
I have a '94 EH3 w/ USDM B18C1, so not sure how much I can help, but I wrote about this extensively here:
https://honda-tech.com/forums/honda-.../#post51107787
Good luck!
Old Dec 26, 2016 | 01:48 PM
BryanM.'s Avatar
Resident Gearhead
The SiR II doesn't even have a purge control solenoid to use the stored fuel fumes in the EVAP canister. So make it look like it's hooked up if you need to, or plug the lines, or my personal favorite: delete the EVAP canister and associated garbage altogether and cap the hard line coming from the fuel tank.
Old Jan 5, 2017 | 08:12 PM
awesome thank you all for the help!
Old Jan 5, 2017 | 09:23 PM
hondaman13's Avatar
That is a good question, i have a JDM B16A and also would like to know if there is a diagram explaining how to hook up all the air hoses that conect to the PCV valve and intake.
jdmjeff
35
Jul 14, 2021 06:47 PM
tgordenDELSOL
Aug 18, 2014 04:44 PM
JdelMsolG
Sep 14, 2006 04:39 AM
Esoterikos
Feb 14, 2004 09:01 PM
DrAwoH
Mar 11, 2002 08:04 AM
