Need Assistance: B18 Turbo Integra "White Smoke" Issues
Old Dec 16, 2016 | 04:25 AM
TurdboTeg's Avatar
Default Need Assistance: B18 Turbo Integra "White Smoke" Issues
I recently purchased a b18b1 integra that's boosted by the previous owner. What a nightmare, I know. Even worse I'm a noob to boost. But for the price I couldn't pass it up.
My question is this, the car runs, and drives, BUT smokes horrible white smoke out of the back and from the wastegate dump(which needs relocated). Yes, I know, white smoke is water/coolant, which says headgasket, but the question I have is what else could this be? It doesn't overheat though.
The compression is horrible. 70 all the way across.
Old Dec 16, 2016 | 06:24 AM
Masterl1nk's Avatar
Default re: Need Assistance: B18 Turbo Integra "White Smoke" Issues
If smoking white, and compression test was horrible, well my friend, your head gasket is screwed up )-:
Old Dec 16, 2016 | 08:58 AM
TurdboTeg's Avatar
Well that doesn't sound too bad! I'll fix it sunday, I'm hoping that is the only issue.
Old Dec 20, 2016 | 05:45 AM
TurdboTeg's Avatar
Is there anything else I can look for to confirm it's a bad head gasket? I wasn't able to get to it this Sunday because of weather.
Old Dec 22, 2016 | 02:27 PM
2kdrift's Avatar
Leakdown test will give you the most information, ie if the pressure from the cylinder leaks into cooling system its very likely HG is the culprit although you can never know exactly until you tear it apart as there are some other issues that can cause this just not nearly as likely
Old Dec 22, 2016 | 10:36 PM
motoxxxman's Avatar
Default Re: Need Assistance: B18 Turbo Integra "White Smoke" Issues
if you don't have a leakdown tester or access to one, just do another compression test, and remove the radiator cap and watch to see if the coolant moves at all with each compression stroke. if it moves even the tiniest bit, HG is blown. don't stand directly over it though, because it can launch our pretty hard if the leak is big enough.
If and when you replace the hg, make sure you bring the head to a machine shop and have them check it for straightness. anything more than 0.002" difference and you'll want to get it shaved. do not skimp out on this. the life of your next hg relies on it
Old Dec 24, 2016 | 04:03 PM
TheShodan's Avatar
Moderator
H-T Code Pro Tip!
Old Jan 2, 2017 | 07:12 AM
TurdboTeg's Avatar
Well, I went to pull the head and when I was pulling the plug wires I found they were completely covered in oil in the 2 middle cylinders. I've never noticed an oil consumption issue though. Hmm.
Old Jan 2, 2017 | 08:28 PM
2kdrift's Avatar
check your spark plug seals under the VC if your lucky it could be as simple as that
Old Jan 3, 2017 | 04:34 AM
TurdboTeg's Avatar
I'm hoping so !!
Old Jan 3, 2017 | 08:06 AM
GoldieWang's Avatar
10 Year Member
I can personally say x2. Just did a HG on a friends single slammer and had to do it more than once. His was out .004" in the dead center between cyl 2 and 3. I told him the clearance and he still didn't want to have it shaved. A week later the HG blew out again. (probably just took that long for him to find it...)
Old Jan 4, 2017 | 12:59 PM
TurdboTeg's Avatar
Noted! I will have it looked at for sure.
Old Jan 6, 2017 | 09:59 AM
TurdboTeg's Avatar
Bad news! Found a crack in the block. Gonna look for a swap. I guess I can do some body and paint work while I search for a new engine.
Old Jan 7, 2017 | 05:36 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
where did you find the crack at?
trojan
Feb 26, 2012 02:18 PM
93califerio
Nov 20, 2011 12:26 AM
ragethemachine86
Oct 3, 2006 09:33 AM
chu77
May 25, 2006 07:55 AM
vtec4u92
Apr 1, 2006 12:15 AM
