Opinion's Needed: A 62mm Turbocharger for an LS/VTEC internally reinforced engine
Old Dec 12, 2016 | 06:25 PM
Nikoboost's Avatar
Icon5 Opinion's Needed: A 62mm Turbocharger for an LS/VTEC internally reinforced engine
I have a precision 6262 turbo and was thinking of putting it on a fully built ls vtec
can anyone give me any input on this turbo or something similar
thanks
Old Dec 12, 2016 | 06:51 PM
turbociv910's Avatar
Default re: Opinion's Needed: A 62mm Turbocharger for an LS/VTEC internally reinforced engine
i made 699 on a old cast 6262 on high 20s boost back in 2011?? e98 fuel
Old Dec 12, 2016 | 07:07 PM
Nikoboost's Avatar
That's really pushing it to the limit tho isn't it there rated for 700hp max did you run that setup frequently or was it a one time kinda thing ?
Old Dec 12, 2016 | 07:11 PM
TheShodan's Avatar
Moderator
They never made a cast wheel 62mm inducer wheel from Precision. You may be referring to their cast 6169 GT35R-based compressor wheel, which was capable of about 61lbs/min airflow. About the 28-30psi level that you're stating.
The first Billet wheels from PTEwere in 2009-2010.
Old Dec 12, 2016 | 07:13 PM
TheShodan's Avatar
Moderator
That is a pretty average amount of power.
Nikoboost, Perhaps if you can tell us the purpose of your LS-VTEC, what your power goal is, what fuel you're running, etc. This would make this discussion go much more smoothly.
Old Dec 12, 2016 | 08:24 PM
Nikoboost's Avatar
Well we can start off with I'm going to use the car for a Sunday driver or taking it to the track every once and a while
my goal was for about 500hp (safely) on pump gas ultra94 (was thinking e85 but not sure where to get it local)
well start with the engine
Motor:
- B18B Block with Golden Eagle Vtec Conversion
- Type R Head ported
- LA Sleeves Bored to 83mm
- CP 9:0:1 Pistons w/83mm Bore and upgraded Wrist Pins
- Crower I-Beam rods with H11 upgraded bolts
- JE Pro Seal Head Gasket
- ARP Bolts and Studs
- Supertech Incolnel Exhaust Valves
- Supertech Nitrate Intake Valves
- Supertech 100lbs Dual Valve Springs
- Supertech Retainers
- Manley Keepers & Locks
- Suoertech Valve Seals
- Skunk2 Pro1 Cams
- 5 Point Main Girdle
- Type R Windage Tray
- Type R Oil Pickup
- LS Crank Micropolished & Balanced
- Type R Oil Pump
- Type R Water Pump
- edlebrock victor x intake manifold
​​​​- aem intake manifold
​​​​​- 750cc fic injectors
- 70mm tb
turbo parts
-precision 6262 t3 v band hot side
-vibrant double back door intercooler
-plm manifold
-tail wastegate
ecu / electronics
-hondata v3 installed in p28
- hondata 4 port boost controller
-hondata 4 bar map sensor
Old Dec 14, 2016 | 07:07 PM
TheShodan's Avatar
Moderator
I'd honestly use something slightly smaller than a 62mm turbocharger, have better control at about 430whp on 93 octane, with less "peaky" power, and you'll have a much better powerband. Get to something about 56-60lbs/min, and you'll be golden.
It's funny when so many people get walked on by smaller turboed/displacement cars with less power over the whole "6262 OMG!!! 500whp on shitty gas".. especially from someone with a turbo about 50lbs/min, similar build as what you propose and less power. Better to work with.
Old Dec 14, 2016 | 07:31 PM
2kdrift's Avatar
IMO 500 HP is more of a track car then a "sunday driver" only thing I can recommend is taking a ride in a 500+HP honda then a 350-400HP honda its kinda something you need to experience, I prefer a wider powerband, let alone all kinds of traction issues
Old Dec 15, 2016 | 03:44 PM
Nikoboost's Avatar
Makes sense I just got the turbo as part of deal with someone maybe I'll hold off on using that and get something smaller
and yeah I know 500hp is too much for a Sunday driver but I will barely use the car for the streets maybe take it to the odd local meet
Old Dec 15, 2016 | 03:59 PM
TheShodan's Avatar
Moderator
Doesn't matter how little or often you use it. If it's uncontrollable without a usable powerband, whether it's just Sunday, or Mon-Fri.. What's the point?
We're not going to change our mind on the 62mm simply because you're reiterating your "frequency of use". That's not the focus of this . You're asking us about using the 6262 on your LS/VTEC, our answer is a resounding NO...
bluteggy00
Feb 4, 2007 06:02 AM
vtectegg
Jul 13, 2005 04:38 AM
teg_love
Sep 21, 2004 10:11 AM
t . b o z
Feb 15, 2004 03:33 PM
JDM DC2
Aug 8, 2002 05:26 AM
