Rpm gauge jumps
Old Nov 28, 2016 | 08:54 AM
Jason Hatcher's Avatar
Default Rpm gauge jumps
what's up fellas.. I hav4e a 96 Honda civic si d16y8.. My rpm gauge jumps around like it has a mind of its own sometimes.... What's happening to my baby??? Haha.. Also the beginning of every gear the car put puts or sputters or hesitates like its not getting enough ... But when i cold crank it runs just fine till it warms up them it
Old Nov 28, 2016 | 10:27 AM
fcm's Avatar
fcm
Old Fart
Default Re: Rpm gauge jumps
Check ICM, a problem with the tach points to an ICM, [igniter] problem, [along with the performance problem]. 94
Old Nov 28, 2016 | 04:33 PM
It was doing it yesterday and hasn't done it since... But what's the easiest way to check the icm
Old Nov 28, 2016 | 06:11 PM
fcm's Avatar
fcm
Old Fart
Pull it and test it, but first, [because it is intermittent check connections to the ICM, unplug terminals clean "crimp" the terminals a little tighter before you plug them back in
Did the performance problem also go away? 94
Old Nov 29, 2016 | 12:13 AM
As for the sputtering... For some reason it went away and the check engine light turned off also
Old Nov 29, 2016 | 08:50 AM
Nope the sputtering is back... I was told to replace my fuel pump... Does this sound about right... Anybody
Old Nov 29, 2016 | 11:16 AM
fcm's Avatar
fcm
Old Fart
Have you checked fuel pressure, is it low?
Replacing parts just because someone tells you to is an expensive way to diagnose a problem, low fuel pressure is more likely to effect engine performance at high RPMs not low, [idle] RPMs.
A permanently mounted FPG is not expensive and a very good diagnostic tool for quick reference at any time you have a problem, I have a B&M permanently mounted at my fuel filter.
fuel pressure gauge | eBay. 94
Old Dec 9, 2016 | 03:35 AM
fuel pressure gauge eBay. 94
mine only sputters when i take off so low rpm's.. It doesn't sputters at high rpm's.. And my engine is sounding like it's whining up with my rpm's
Old Dec 15, 2016 | 01:43 PM
motoxxxman's Avatar
you had a cel. retrieve the trouble codes. the on-board diagnostic (obd) system exists for a reason. use it
Methane2k2
Aug 3, 2005 10:39 PM
itr_dc2
Dec 5, 2004 03:50 PM
Tifflec
Jul 14, 2004 01:29 PM
fred92htch
Jan 14, 2003 04:41 PM
fred92htch
Nov 13, 2002 07:11 PM
