Rpm gauge jumps
Rpm gauge jumps
what's up fellas.. I hav4e a 96 Honda civic si d16y8.. My rpm gauge jumps around like it has a mind of its own sometimes.... What's happening to my baby??? Haha.. Also the beginning of every gear the car put puts or sputters or hesitates like its not getting enough ... But when i cold crank it runs just fine till it warms up them it
Old Fart
Re: Rpm gauge jumps
Pull it and test it, but first, [because it is intermittent check connections to the ICM, unplug terminals clean "crimp" the terminals a little tighter before you plug them back in
Did the performance problem also go away? 94
Old Fart
Re: Rpm gauge jumps
Have you checked fuel pressure, is it low?
Replacing parts just because someone tells you to is an expensive way to diagnose a problem, low fuel pressure is more likely to effect engine performance at high RPMs not low, [idle] RPMs.
A permanently mounted FPG is not expensive and a very good diagnostic tool for quick reference at any time you have a problem, I have a B&M permanently mounted at my fuel filter.
fuel pressure gauge | eBay. 94
Re: Rpm gauge jumps
fuel pressure gauge eBay. 94
