Tachometer problem
Old Nov 11, 2002 | 05:53 AM
fred92htch's Avatar
Default Tachometer problem
I posted this in the EG forum also
I had this problem a few months ago and never figured it out, it just went away. Well, now it’s back. I have a factory gauge cluster with tach. What’s happening is my tachometer is lagging behind my engines actual RPM’s. The best way I can describe it is it seems like the needle has extra weight on it or is in a bind. Before, when I was going 70 mph, I would be reading about 3200-3500 RPM’s. Now, it’s about 2100. If I go WOT, it will finally jump and read almost all the way to redline, however, it hit the rev limiter at 7500 instead of around 8000-8200. I don’t know how to check the gauge itself or unit that sends the signal.
Where is the sending unit for the tach? Will this affect when vtec engages?
Any idea’s are welcome. Thanks
Old Nov 11, 2002 | 12:49 PM
fred92htch's Avatar
Default Re: Tachometer problem (fred97gle)
Anybody know how I can check this with an ohm meter?
Old Nov 11, 2002 | 01:10 PM
RAWB's Avatar
Here's how to fix the problem on a G2 Teg, should be the same for you.
http://www.g2ic.com/tegtips/engine/10.html
Old Nov 12, 2002 | 06:11 AM
fred92htch's Avatar
Default Re: Tachometer problem (integracon)
Thanks for the link, I'll try that this afternoon.
Old Nov 12, 2002 | 01:26 PM
fred92htch's Avatar
That brings up another question. Does this send a signal to the ECU? If so, then it would seem like it would affect the vtec crossover point. Like engage vtec at the wrong RPM.
edited spelling
[Modified by fred97gle, 4:27 PM 11/12/2002]
Old Nov 12, 2002 | 09:24 PM
fred92htch's Avatar
It didn't work. Actually the link is for a tach that is bouncing. Mine is acting more like it's on novacain.
[Modified by fred97gle, 8:18 AM 11/13/2002]
Old Nov 13, 2002 | 01:28 PM
blacksheep's Avatar
My tach was giving me the bouncing problem, with a simultaneous engine skip. Now the engine runs fine, but the tach has quit working altogether. What can I do to fix this?
Old Nov 13, 2002 | 07:09 PM
fred92htch's Avatar
Default Re: Tachometer problem (blacksheep)
This thing has been wracking my brain. Well, I took out the gauge cluster today and took the tach out also. I put some machine oil on the shaft holding the needle, put it all back together and it works now... Perfect. I don't know if it was from taking the connections apart and putting them back together that did it or the oil. Either way I'm glad.
Old Nov 14, 2002 | 02:28 PM
blacksheep's Avatar
I'm gonna take my guage cluster out tonight when I get off. I'm going to check all the connections. Hopefully mine will work when I put it back in. I guess I'll use my JDM cluster while my GS-R one is out.
Old Jan 14, 2003 | 11:19 AM
blacksheep's Avatar
I know this post is old, but it wasn't the cluster. Haven't worked on the car in a while, but it's still not working.
Old Jan 14, 2003 | 11:56 AM
ejprimo's Avatar
i seem to have the same problem on my stock tach. the rpm gauge will read fine until i hit vtec and then the needle stalls for a second but the needle can not catch up to the actual rpms of the engine. im want to get this fixed cuz im afraid of over-revving the motor.
Old Jan 14, 2003 | 11:59 AM
CHEETAH's Avatar
sometimes a loose ground will cause that ...
greg
Old Jan 14, 2003 | 04:41 PM
skierGT's Avatar
Default Re: Tachometer problem (CHEETAH)
do u have white faced gauges or anything
my friend put in white faced gauges wrong and they pushed on the needle and when it was cold out it wouldnt go up either fast enough or at all.
e-Roc
Jun 25, 2006 07:16 PM
Methane2k2
Aug 3, 2005 10:39 PM
JDMKid71
Jun 27, 2005 09:55 PM
fred92htch
Nov 13, 2002 07:11 PM
PoWeRBaN_PaNdA
Aug 28, 2002 02:48 PM
