Fellow tuners pls help me fix my POS!!!!
Ok so I have a gorgeous 95 Integra GSR. Fully built, pistons and rods, cams turbo charged running Hondata S300. When I turn on the car heavy white smoke pours out of the exhaust. Everyone says the head gasket but I changed that about a year ago. When I check the oil there is no coolant showing on the dipstick. Also it seems like the smoke is coming like from somewhere in the engine bay. Soon as I start the car and give it a little gas the smoke starts coming from underneath the car. A couple other issues are the turbo won't boost past 8 lbs. I took the filter off the turbo and noticed just a tiny a midget of oil. I know I need can seals as we'll because I can see and feel oil behind the cams. That's about All the info I hav. I know it's kind of vague but any help would be appreciated. Also I'm located on the eastern shore of Maryland so if anyone knows of a decent and fair shop let me know!!!!
Need to know exactly where smoke is coming from.
White "smoke" is a sign of a blown HG, you do not need to see coolant in the oil or oil in the coolant to have a blown HG, eliminate it as a possibility by doing a compression test. 94
xchipx
Sep 19, 2010 08:52 AM
jdmcreations777
May 30, 2007 11:41 AM
